Blackview BV6000 is an IP68 certified device with quite good specs such as Helio P10 octa-core SoC 3GB RAM, Android 6 out of the box, 4,200mAh battery and 13MP camera on the back coming on May 31st.
Being IP68 certified is not a panacea and it doesn’t mean that you can dive in the sea and get away with a working device. Nevertheless, Blackview is not afraid and put the BV6000 through a really risky test: Put the device in a washing machine and the device survived and was fully working afterwards!
Check out the full specs and the washing test on the video below.
MT6755 Octa-core 2.0 GHz 3GB RAM/32GB internal storage (TF 32GB) Android 6.0 IP68 4.7 inch HDips 720*1280 3rd generation Corning Gorilla glass, 5th class, can be operated even with gloves on CNC metal frame 2G: GSM 850 / 900 / 1800 / 1900 3G: WCDMA 900 / 1900 / 2100 4G: FDD-LTE 800 / 1800 / 2100 / 2600 4500mAh Battery 5.0MP OV5670 85°wide angle front camera, 13.0MP OV top level rear camera, f2.0 GPS+GLONASS dual-satellite navigation system Double Mico-SIM card slot, dual standby, one talk 5V2A fast charge Customizable UI 5GHz WIFI NFC Atmosphere pressure sensor Compass Gyroscope Snapshot Button GPS + GLONASS SOS button Double click wakeup Color Options Army Green, Sunshine Yellow, Violet Black
