The phone comes with just a power plug and the USB cable.
Blackview BV2000s: DESIGN
The device is very compact as it has a 5” display and the phone is made of plastic. My review unit comes in white colour but it has a lot more other colour options.
On the front top there is a 2MP snapper along with other usual stuff. On the bottom you can find a physical home button and non-backlit capacitive keys.
On the back you can find an 8MP shooter with dual LED flash and the speaker grill.
The buttons are located on the right side and they have a great tactile feedback.
Under the hood, there is a removable 2400mAh battery, two SIM card slots and the microSD card slot.
Overall, the phone is well built and I have no complaints at all.
Blackview BV2000s in pictures:
When it comes to the battery life, it is pretty good. The 2400mAh unit can last you a full day and you will get around 4 hours of screen-on time on light usage.
Blackview BV2000s: CONCLUSIONS
The Blackview BV2000s is indeed a cheap phone and you can get it for less than $70. It has a decent design and good build quality, and a pretty good display for such a low price.
Also, the UI and even gaming performance is pretty good and I can see a noticeable upgrade over the previous BV2000 model.
However, the camera is kind of disappointment but this is what you get with the phones this cheap.
All in all, Blackview BV2000s is a pretty good offering for a very low price of just below $70. While it is not perfect as the camera does not impress but it does other things pretty much right and you simply cannot expect more for the price.
