The vast amount of high-end devices may be overwhelming , but low-ends are still here. Anyway, the company has always been popular for its very affordable devices. And this is the case with its new device, the Blackview E7. And it will sell for just $79.99.
The awesome price doesn’t mean it lacks specs. On the contrary. For starters, Blackview E7 features the quad-core MT6737 SoC. A SoC that supports 4G LTE connection and smooth gameplay with its Mali T720 GPU. It retains the mainstream 5.5″ display size with a resolution of 1280×720 pixels. To continue, the main camera is an 8MP with LED flash while the front is a simple 2MP one. The RAM amount is a bit anemic at 1GB, but fortunately, the Android 6 is light enough to cope with it. On the contrary, the internal storage of 16GB is enough, as you can add up to 64GB more via microSD. Of course, Dual-SIM support is a standard with Chinese manufacturers. What’s not a standard at this price tag is the fingerprint sensor that is present. Lastly, the battery is more than enough for the SoC, at 2.800mAh.
The Blackview E7 is already in stock at Aliexpress for the low price of $79.99. It comes in three colors, Pearl White, Stardust Grey and Sky Blue. You can find more info for the device on the official product page here. Below you can watch the device in action.
