ASUS Zenfone Max is one of the special smartphones in the market that cater to the needs of the large battery lovers. Given that the phone features modest specs, the phone should give you at least a couple of day’s of charge, which is quite good for a sub-$200 smartphone.
The Zenfone Max come with a large 5000mAh battery to keep your phone running all day long. It is powered by the modest Snapdragon 410 quad-core 64-bit processor with 2GB of RAM on board. While this isn’t a powerful chip, its pretty decent for an entry level device and will further aid in increasing the battery life of the device.
You get a large 5.5-inch display with 1280 x 720 pixel resolution IPS display. As for the optics, the rear camera will be of 13MP while the front shooter is of 5MP. You get 16GB of internal storage with the option to further expand up to 128GB via a MicroSD card slot.
As for the connectivity features, you have Wi-Fi, Bluetooth 4.0, 4G, GPS, GLONASS, A-GPS and dual SIM dual standby support. The support 4G bands are as follows TDD (B39 1900MHz), TDD (B38 2600MHz), FDD (B3 1800MHz), FDD (B1 2100MHz), TDD (B41 2500MHz), TDD (B40 2300MHz). Finally, for software, you get Android 5.1 Lollipop OS out of the box.
As you can see, the specs are just decent for its price. But what really sets the phone apart from the crowd is its large battery. So, if you are in the market looking for a phone that can last long, the Zenfone Max could be a good option. Check out more information from the link below.
