Usually niche products, such as smart phones for women, significantly more expensive than counterparts without restrictions on the floor. In addition, women’s smartphones will never shine high performance. Against this background, new Alva Slim Note looks like a black sheep, because despite the feminine orientation smartphone received high performance and affordable price.
Alva Slim Note features a large 5.7-inch LTPS display with a resolution of 1920 x 1080 pixels, which is coated with Corning Gorrilla Glass 3. How to fableta with the diagonal it is not large dimensions – 158.1 x 78.5 x 7.9 mm (weight 170 g). This is partly merit ultranarrow frames on each side with a width of 1.6 mm.
Also Alva Slim Note please cameras, front received a 5 megapixel resolution, viewing angle of 87.5 degrees, the aperture of F/2.2, rear – 13 megapixel, BSI, aperture F/2.0. In this application for “camera” meets the appropriate utility Color OS firmware from Oppo, since it is installed by default on your smartphone (based on Android 4.2.2).
The smartphone works with two SIM-cards (TD-SCDMA + GSM) and is based on an 8-core CPU MT6592 with 1.7 GHz, while the RAM to 2 GB. Unfortunately, Alva Slim Note can not boast good battery – 2250 mAh capacity total.
Sales unit presented in two colors – white and pink. Cost model with 16 GB of flash memory was 1499 yuan ($ 240), a model with 32 GB – 1799 yuan ($ 289). Currently Alva Slim Note is only available for pre-order.
Translated from original source
