Ado Mate 3 Bluetooth Speaker Review – Awesome Tiny Speaker!
  • #9146
    Ado Mate 3 Bluetooth Speaker Review: VIDEO
    Ado Mate 3 Bluetooth Speaker Review: UNBOXING
    IMG_2515
    This little device comes in a nice looking box and all you are getting is the USB charging cable and some documentation.
    Ado Mate 3 Bluetooth Speaker Review: DESIGN
    IMG_2512
    The very first thing you’re going to see is that the speaker is very tiny and lightweight. It is 5cm long and 5cm wide, and it weighs just 115g despite the fact that it has a huge 1800mAh battery.
    IMG_2483
    The speaker is very well made and it has a rubberised plastic finish. It can be charged via the micro USB port and the battery is said to last up to 20 hours, which is amazing. During my testing I could achieve around 15-16 hours, which is really incredible for a speaker of this size.
    IMG_2486
    The only button this device has is the power switch, which also acts as a play/pause button and it has a blue backlight.
    IMG_2485
    On the top is the 4W speaker grill along with the NFC for a super fast pairing and on the bottom there is a silicone padding to prevent the speaker from sliding.
    IMG_2490
    Overall, the speaker has a great build quality and design, and it is so compact that it can fit even in the pocket.
    Ado Mate 3 Bluetooth Speaker Review: PAIRING
    IMG_2511
    Pairing the Ado Mate 3 is super easy as the pairing mode turns on automatically once you power on the device.
    Ado Mate 3 Bluetooth Speaker Review: SOUND QUALITY and VOLUME OUTPUT
    IMG_2507
    You will be blown away how loud this thing is and the sound quality is very good considering the size of the speaker. Also, there are no crackling noises even at the highest volume settings. Overall, I am very impressed with it.
    Ado Mate 3 Bluetooth Speaker Review: CONCLUSIONS
    IMG_2487
    I was really impressed by the Ado Mate 3 Bluetooth speaker and it is hard not to recommend it. You can get it for as low as $16 and I will leave a link in the description below this video. You will get a very portable, lightweight speaker, which has a great build, design and it has a great sound quality. Finally, you will be literally blown away how loud it is and the battery just lasts forever.
    Buy Ado Mate 3 Bluetooth Speaker
