Be Elite (how to know which rom works)
Home Forums Android Software Help Requests Be Elite (how to know which rom works)
This topic contains 2 replies, has 3 voices, and was last updated by  Rohan99 4 years, 6 months ago.
  • #5064
    rocky.aj
    i have a B.Elite chinese mobile phone and i got it rooted with superSU. when i first got it, the options said mako or whatever the default nexus 4 details are. and i just am wondering how to figure out which ROM would work fine on it without any bricking or losing any of the specs of the mobile. what details do i have to supply for any answers? thank you a lot in advance
    p.s: if anyone wants the phone website link just search for be elite mobile on Google and then you can find their official website.
    #15834
    i dont know about the chines mobile………
    #17575
    Rohan99
    Just look for the firmware that is for your particular phone’s model and make. Once you get a rom that was made specifically for your phone then you should not have any problems. It is also likely that if you try to flash a rom that was not made for your phone, it will not install and so your phone will be protected from being bricked where firmware is concerned.
