Tuesday, January 17, 2017
THL W9 Android 4.2 3G 5.7 inch Quad Core Smart Phone
Home Forums Android Software News about Android THL W9 Android 4.2 3G 5.7 inch Quad Core Smart Phone
This topic contains 1 reply, has 2 voices, and was last updated by  1949deal 2 years, 9 months ago.
  • #5033
    arigbuy
    Important parameters
    Brand: THL
    Model: W9
    Type: 3G Phablet
    RAM: 1GB
    ROM: 16GB
    IPS, capacitive (5-point) touch screen
    Network frequency: GSM 850/900/1800/1900MHz WCDMA 850/2100MHz
    Dual SIM, Dual standby
    Dual cameras (the back one with flash light and auto focus)
    Wireless internet
    Gravity sensing system
    Color: White
    OS: Android 4.2
    CPU: MTK6589 Cortex-A7 Quad Core 1.2GHz
    GPU: PowerVR SGX544MP
    Basic parameters
    WiFi: 802.11b/g/n wireless internet
    Network type: GSM+WCDMA
    Frequency: GSM 850/900/1800/1900MHz WCDMA 850/2100MHz
    Support 3G : Yes
    GPS: Yes
    Internal memory: 13.65GB
    RAM: 1GB
    ROM: 16GB
    External memory: TF card up to 32GB (not included)
    Product size: 158 x 82 x 11 mm
    Package size: 191 x 112 x 63 mm
    Product weight: 174 g
    Package weight: 0.75 kg
    Bluetooth: Yes
    Screen type: Capacitive
    Screen size: 5.7inch
    IPS: Yes
    Screen resolution: 1920 x 1080 (FHD)
    [hr]
    Feiteng H80W Android 4.2 3G Smartphone
    Main Features:
    Type: 3G Smartphone
    OS: Android 4.2
    CPU: MTK6572 Cortex-A7 Dual Core 1.2GHz
    RAM: 256MB (229.72MB available)
    Dual cameras
    Wireless internet
    FM/MP3/MP4/GPS/Bluetooth function supported
    ROM: 256MB (196.89MB available)
    Capacitive (2-point) touch screen
    Display:
    Screen size: 4.0 inch
    IPS: No
    Screen resolution: 320 x 480 (HVGA)
    Camera:
    Back camera: 2.0MP
    Front camera: 0.3MP
    Camera type: Dual cameras (one front one back)
    Video recording: Yes
    Specification:
    Network:
    Support 3G: Yes
    GPS: No
    Bluetooth: Yes
    [hr]
    Basic parameters
    Exposure Date: 2013
    Phone type: 3G mobile phones, smart phones, camera phones, tablet phone
    Designs: candy bar
    Main Screen Size: 5 inches
    Touch screen: capacitive screen, multi-touch
    The main screen material: IPS
    The main screen resolution: 1920×1080 pixels
    The main screen color: 16 million colors
    Screen pixel density: 441ppi
    Network type: dual card dual-mode
    Network mode: China Unicom 3G (WCDMA), China Unicom 2G / mobile 2G (GSM)
    Data services: GPRS, EDGE, HSPA
    Support band: 2G: GSM 900/1800
    3G: WCDMA 850/2100MHz
    Theoretical rate: HSDPA: 7.2Mbps
    HSDPA: 5.76Mbps
    Key Type: touch keys
    Colors: white, gray
    Mobile Size: 144×71.2×8.6mm
    Hardware parameters
    Operating system: Android OS 4.2
    Cores: Quad-Core
    CPU Model: MediaTek MT6589T
    CPU Frequency: 1536MHz
    GPU Model: Imagination PowerVR SGX544
    RAM capacity: 2GB
    ROM capacity: 32GB
    Memory card: do not support the capacity expansion
    SIM Card Type: SIM card / Micro SIM card
    Battery Type: non-removable battery
    Battery capacity: 2000mAh
    #16406
    It has only rom 16gb, but THL W200S has larger 32gb rom and octa core cpu, you can check on 1949deal, it’s only $189.99 now!
