Tuesday, January 24, 2017
Stylus for Android Devices
Home Forums Android Software General Discussions about Android Stylus for Android Devices
This topic contains 13 replies, has 9 voices, and was last updated by  Chinaren 4 years ago.
Viewing 14 posts - 1 through 14 (of 14 total)
  • #3402
    lindbergh
    Do you think a stylus (a pen-like device) would make an android device more functional? Or do you think that it’s the other way around? I think a stylus adds more functionality to Android devices. Let’s just take a look at the Samsung Galaxy Note 10.1 and the Galaxy Note II. Both these devices have a stylus that adds a lot of features to the device. What do you think?
    #12771
    Memento_Mori
    Something like the curved plastic tab attached to the optional wrist strap that was used for the 3DS would be much better I think. Especially for some games where you need both hands.
    #12778
    macpdiaz
    If you’re asking if the stylus alone can make an android device functional, it would really depend on the user. It can deliver more precise actions like tracing or cutting around pictures or writing down something. If you use none of that, then a stylus wouldn’t be any help.
    However, on the hardware side, it can do a lot of things. One, less possibility of scratching your screen (protector) or smudging your screen with your fingerprint. But you also have to consider if the device is built for a stylus since not all devices (or at least, most devices that has a capacitive multipoint screens) are meant to be used with a stylus.
    #12786
    man007
    I have a Motorola Xoom 2 which is a 10.1 inch tablet. I have to say that the only think that offers me a stylus is that it don’t left fingerprints on the screen, nothing else…
    #12791
    lindbergh
    You’re definitely right.
    I like to draw and paint a lot. A stylus could greatly help me in making “works of art”. Also, if you are going to use hand writing to text feature, a stylus would really be of much help.
    #12794
    droidster
    I never really liked PDA’s and adding a stylus to a Smartphone, basically means you are turning it into a PDA. Another reason I don’t like styluses is that they tend to get lost or brake, you rarely encounter this problem when using your finger.
    #12802
    macpdiaz
    @droidster
    well, technically you can also break your finger haha. kidding aside, i used to say the same thing but when I got to use the stylus of a friend’s Galaxy Note II, i changed my mind. I want a stylus to work like that.
    #12810
    droidster
    I know that’s why I said “you rarely encounter this problem” :).
    I can’t comment on how well the stylus integration is realized on the Note since I have never used one. In all honesty it does make sense to have a pen shaped controller for something called Note, but for the day to day uses I still think fingers are a step forward.
    #12811
    lindbergh
    macpdiaz wrote:
    @droidster
    I’m really excited with the Galaxy Note II. They say that it even detects different levels of pressure. I can’t wait to get my hands on it this Christmas. Steve Jobs always said that the stylus would only ruin the experience. I think he was dead wrong.
    #12835
    so far, i’ve never encountered the need to use a stylus. i would imagine that it would help especially with drawings and accuracy. but for me, it’s just nice to have.
    #12842
    Norrwen
    I don’t think I would need to use a stylus. It’s just another thing that someone can easily use. Too much of a hassle to remember two things instead of just my phone.
    #12955
    Anonymous
    Yes, now that the weather’s cold I find it very hard to use my phone with gloves on. This should go over well.
    #12956
    NextLT
    No not at all.
    I think that defeats the purpose of a smart phone and it will be taking us back a few years.
    #12957
    Chinaren
    I have a stylus (okay: s-pen) with my Note II, and I rather like it. That said, I don’t use it very often, but the handwriting recognition on the N2 is really good, so I do sometimes write any long text messages with it, as it’s a bit faster than the usual fashion.
    It’s also nice to use when making notes and drawing.
    However, it’s not essential and I probably wouldn’t really miss it if I didn’t have it. Then again, I bought the Note over the S3 partly because of the stylus.
