Tuesday, January 24, 2017
Meizu M1 Note vs Meizu M2 Note: Is The New Phone an Upgrade or Downgrade?
Home Forums Android Hardware News on Android Hardware Meizu M1 Note vs Meizu M2 Note: Is The New Phone an Upgrade or Downgrade?
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 7 months ago.
  • #8534
    The Meizu M1 Note was originally launched sometime in December of last year and half a year later the company has already announced its successor, the M2 Note. But is Meizu’s newcomer really an upgrade over its predecessor? We check out and compare the specs of both devices to see what Meizu has brought with the new M2 Note.
    meizum1notevsmeizum2note-01
    Display
    Both the M1 Note and M2 Note feature the same display, a 5.5-inch IPS LCD display with a resolution of 1920 x 1080 pixels and a pixel density of 401ppi, so there’s not much to compare between the two devices in this area.
    Camera
    Meizu has also decided to equip the M2 Note with the same set of cameras as the ones found on the M1 Note namely a 13-megapixel f/2.2 rear camera with dual LED flash and a 5-megapixel front-facing camera so again there’s not much to compare in this department.
    Processor & RAM
    The processor is the first and probably biggest change the company has made with the M2 Note. The new smartphone uses the newer MediaTek MT6753 SoC compared to the MT6752 found on the M1 Note but the company has weirdly decided to clock the M2 Note’s processor to only 1.3GHz while the M1 Note’s processor was set at a faster 1.7GHz.
    The GPU found on the M2 Note is also the slower Mali-T720 MP3 which runs at only 450Mhz while the M1 Note featured the 700MHz Mali-T760.
    In the RAM department, both devices feature the same 2GB of LPDDR3 RAM.
    Storage & Battery
    When it comes to storage, both devices feature the same 32GB of internal storage but the newer M2 Note has added expandable storage support via microSD cards up to 128GB. The M2 Note is able to do this by using a hybrid SIM card slot which can contain either a SIM card or a microSD card.
    As for its battery, Meizu has equipped the M2 Note with a slightly smaller 3100mAh battery compared to the 3140mAh battery found on the M1 Note.
    Conclusion
    Based on these comparisons, it’s hard to say whether the M2 Note is a straight upgrade to the M1 Note due to what look like downgrades in some areas like the device’s CPU and GPU.
    We assume the compromises were necessary to bring down the new smartphone’s price to a surprisingly low $160. We’ll have to wait and see if the performance of the M2 Note matches up to its predecessor to justify the downgrades for the lower price tag.
