Tuesday, January 17, 2017
Love Scanner Fingerprint Prank
Home Forums Android Software Apps, Games & Utilities Love Scanner Fingerprint Prank
This topic contains 0 replies, has 1 voice, and was last updated by  killu 4 months, 2 weeks ago.
  • #11719
    killu
    Do you want to calculate the loves between two person?. If you want to know how much passion they have each other than download Love scanner fingerprint prank app to calculate the percentage of devotion. We are giving it free for calculation by scanning fingers!
    Yes by scanning fingers and find out love percentage. Scan each finger of both lovers and the love meter pro will show you how compatible your affection are. Love meter pro is the best app in the play store to calculate attractiveness match and bad match. The magic of finger is here!
    How to use:
    – It’s simple to use just place your fingertips on the scanner and wait for few seconds and you will automatically
    receive your loves calculation result and see if you’re a good match or bad match.
    – The Fingerprint love scanner prank app is the perfect app for fun for all age. You can also have fun with this love
    calculator during a parties or on date.
    – On the basis of fingerprints result would be between 50% to 100%. If the love meter pro indicates 100%, it means
    you are a perfect love match, and that you have passed the couple loves test and if loves scanner prank app
    shows 50% or more less than 100% its mean you are good or bad in love.
    – Love scanner fingerprints apps is ideal and perfect for valentine’s day and lovers’ holiday and a perfect way to
    check you love compatibility.
    – The best prank calculator app that shows love meter pro between the couples.
    – Put your fingers on scanners and get awesome and accurate loves match by prank calculator.
    Download now love scanner fingerprint prank and calculate Percentage.
    Link to Download: https://play.google.com/store/apps/details?id=com.appmonkey.monkey_lovemeter
    [IMG]https://lh3.googleusercontent.com/3FeVvWT21_SeymhhTIRZXCEW7jGQWuL2G0u_lwTavVBuBwIUUvQR566xXq3eWX88mTc=h900[/IMG]
