Wednesday, January 25, 2017
Huawei Honor Zero Smart Band Review
Home Forums Android Hardware News on Android Hardware Huawei Honor Zero Smart Band Review
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 6 months, 1 week ago.
  • #11244
    Huawei has been known not only for its mobile phones but also for quite a few wearable devices. The Honor Zero is one of them. It is stylish, well-built and it quite affordable. Learn more in our full review.
    Thanks to Tomtop for sending Huawei Honor Zero Smart Band for a review
    Buy Huawei Honor Zero Smart Band
    Huawei Honor Zero Smart Band Review: UNBOXING
    IMG_2980JPG IMG_2981JPG
    The smartwatch comes in quite a premium box (the presentation reminds me the Huawei P8’s box).
    The contents include some instruction manuals and a magnetic charging cable, which stays firmly when attached to the bracelet.
    Huawei Honor Zero Smart Band Review: DESIGN and DISPLAY
    IMG_2982JPG
    As for design, the smart band is similar to a classic watch due to its round shape. The device is very well-built and it uses a metal frame, which goes around the display.
    IMG_2988JPG
    Also, the bracelet is very light (25g) and it is IP-68 certified, meaning that it is water and dust resistant.
    IMG_2985JPG
    On the back, we have pins for charging.
    IMG_2986JPG IMG_2983JPG
    The band is made of textured rubber and it is comfortable to wear. You don’t have that irritating feeling after you wear the watch for a long time.
    20160720_121544
    The smart band does not have any buttons and everything is controlled by tapping the touchscreen.
    IMG_2990JPG
    As for display, it uses Amoled technology. It is bright and has a great sunlight legibility (tested both in a cloudy day and under direct sunlight).
    Huawei Honor Zero Smart Band Review: FEATURES and FUNCTIONALITY
    20160720_121556
    In order to light up the display, you have to simply lift and turn your wrist.
    The smart band has some basic features like clock with the ability to select from a variety of watch faces.
    Also, we can see the number of steps taken and calories burned, sleep quality information, stopwatch and adjust some basic settings.
    In order to take a full advantage of the smart band, you have to download the Huawei Wear application. I didn’t have any issues pairing my phone with the bracelet and it offered to upgrade the firmware.
    Within the app, you can track your fitness goals, choose different activities, adjust various settings and so on. Also, you can receive calls, SMS, Facebook and some other notifications on the display of the bracelet.
    IMG_2992JPG
    I didn’t have any connectivity/syncing issues with the device.
    Huawei Honor Zero Smart Band Review: BATTERY LIFE
    20160720_130035
    The battery life could be better. I could get just over 3 days of moderate use when I used the display quite often.
    A great thing is that you can fully charge the device in less than 1 hour.
    Huawei Honor Zero Smart Band Review: CONCLUSIONS
    IMG_2987JPG
    At the price of $66, the Huawei Honor Zero may not be the cheapest smart band around but it is worth the price if you are looking for a basic fitness tracker, which is comfortable to wear and has a premium design with a great display.
    IMG_2991JPG
    Also, it tracks your steps accurately, gives you notifications of calls, texts and more.
    20160720_121556
    However, keep in mind that it lacks some extra features like a heart rate monitor. Also, the battery life could be better, especially if you are coming from the Xiaomi Mi Band 2.
    Buy Huawei Honor Zero Smart Band [source]
