Wednesday, January 18, 2017
Google Play Store problem
Home Forums Android Software Help Requests Google Play Store problem
This topic contains 1 reply, has 2 voices, and was last updated by  imported_umit 3 years, 2 months ago.
  • #4763
    Psylight7
    Hello guys!
    I’m new at this forum so let me introduce first.
    My name is Diogo, 25 years old and i’m from Lisbon.
    I register on forum because i bought a “Butterfly S6 Smartphone Android 4.2 MTK6589 Quad Core 3G GPS WiFi 5.0 Inch” and I’m very satisfied with my mobile.
    My problem is that i can’t open Google Play Store on my device after installed.
    I downloaded the Google Play Store.apk from web and then I install it on my Android; Then when i open, the app automatically closes without having time to do anything…
    Because of that i can’t even install more apps for my Android.
    Is there anything i can do to put the Google Play Store app working fine?
    Thank you so much, have a nice day!
    #14816
    I don’t think google play apk alone is enough. As far as I know, it works with other apps. You may need to install google services and others also. You need to make a search.
