Sunday, January 22, 2017
Get the Cubot X17 4G Smartphones for Only $149.99 at GearBest.com
Home Forums Android Hardware News on Android Hardware Get the Cubot X17 4G Smartphones for Only $149.99 at GearBest.com
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 11 months, 4 weeks ago.
  • #10134
    GearBest.com is putting the Cubot X17 4G smartphone on sale next week which will reduce the price of the X17 by $20 but only 150 units will be available during the promotion so stocks are expected to go out fast. The sale, which starts on Monday, brings the price of the Cubot X17 down to $149.99 from its original price of $169.99.
    gearbest-cubot-x17-sale-01The Cubot X17 is the latest flagship smartphone from the Shenzen, China-based manufacturer. It features a 5-inch full HD 1080p display with a pixel density of 441ppi, a MediaTek MT6735A 1.3GHz 64-bit quad-core processor, a Mali-T720 graphics chip, 3GB of RAM, 16GB of internal storage, dual SIM dual standby support, and 4G LTE connectivity.
    The X17 is also equipped with a 16-megapixel rear camera with dual LED flash, an 8-megapixel front-facing camera, a dual SIM card tray that supports one Nano SIM and one Micro SIM card, and a 2500mAh battery.
    Buying the Cubot X17 from GearBest.com will get you, aside from the smartphone itself, a power adapter, a USB cable, a protective case, a screen protector, a cleaning cloth, an English language manual, and a SIM card tray ejector pin.
    As previously mentioned, the Cubot X17 4G smartphone will be available for only $149.99, a $20 discount, next Monday over at GearBest.com.
