【Pre-Orders】Three Types of BlitzWolf USB Reversible Data Cable with discount
- This topic has 1 reply, 1 voice, and was last updated 10 years, 10 months ago by
banggood.
December 4, 2015 at 10:00 AM #9774
banggood
ParticipantHi, Droidchina friends,
Three kinds of BlitzWolf USB Data Cable can be pre-ordered from now on.
Preorder Discount Before 1000th Orders
$3.59 0-50th orders
$3.99 51-200th orders
$4.59 201-500th orders
$4.99 501-1000th orders
Normal price: $5.99
Product information:
Brand: BlitzWolf™
Model: BW-TC1
Material: Protective Tinned Copper Mesh + Aluminum Foil Shielding + Environmental Flexible PVC Jacket
Plug: Standard USB3.0 A Male to Double-Sided USB3.1 Type-C Male, Nickel-plated Reversible Connector Head
Wire Core: 32 AWG(Data)*3 + 24 AWG(Power)
Output: 5V/9V/12V, up to 3A
Data Sync Speed: Up to 5Gbps
Length: 1m/3.33ft
OD: 4.5mm
Color: BlackProduct description:
Double-Sided Plug Design: The cable uses a double-sided USB3.1 USB Type-C male reversible plug allowing you to plug it in
without needing to recognize the positive or negative, just like the apple lightning cable.URL: BlitzWolf™ PVC 3.0 Type-C
[size=large]BlitzWolf™ 2.4A USB Type-C Reversible Braided Data Cable 3.33ft/1m USB 2.0 A Male to USB 3.1 Type-C Male for Nexus 5X 6P OnePlus 2 Nokia N1 Xiaomi 4C Zuk Z1[/size]
$3.99 0-50th orders
$4.59 51-200th orders
$4.99 201-500th orders
$5.59 501-1000th orders
Normal price: $6.99
Brand: BlitzWolf™
Model: BW-TC2
Material: Protective Tinned Copper Mesh + Aluminum Foil Shielding + Environmental Flexible Braided Jacket
Plug: Standard USB2.0 A Male to Double-Sided USB3.1 Type-C Male, Nickel-plated Reversible Connector Heads
Wire Core: 30 AWG(Data) + 24 AWG(Power)
Output: 5V/9V/12V, up to 2.4A
Data Sync Speed: Up to 480Mbps
Length: 1m/3.33ft
OD: 2.8mm
Color: Black Cable & Gray Metal Plug, Red Cable & Black Metal PlugURL: BlitzWolf™ 2.4A USB Type-C Reversible Braided Data Cable 3.33ft/1m
[size=large]BlitzWolf™ 2.4A USB Type-C Reversible Braided Data Cable 6.56ft/2m USB 2.0 A Male to USB 3.1 Type-C Male for Nexus 5X 6P OnePlus 2 Nokia N1 Xiaomi 4C Zuk Z1[/size]
$4.99 0-50th orders
$5.59 51-200th orders
$5.99 201-500th orders
$6.59 501-1000th orders
Normal price: $7.99
Brand: BlitzWolf™
Model: BW-TC2L
Wire Core: 28 AWG(Data) + 22 AWG(Power)
Length: 6.56ft/2m
OD: 3.5mm
Color: Black Cable & Gray Metal Plug, Red Cable & Black Metal PlugURL: BlitzWolf™ 2.4A USB Type-C Reversible Braided Data Cable 6.56ft/2m
Have fun,
Doris LeeDecember 15, 2015 at 3:06 AM #18552banggood
ParticipantHi, DroidChina friends,
This cable is designed to be compatible with all micro USB devices; however, some unbranded devices use substandard
micro USB ports that might damage the cables connector, in these cases we recommend you use the original charging cable.The key to the dual sided operation is the inner core. It is made of a thin but tough, flexible and guidance plastic that ensures a
tight reversible connection to your device. :blush::blush:It’s available on Banggood now.
Brand: BlitzWolf®
Model: BW-DC1
Material: Protective Tinned Copper Mesh + Aluminum Foil Shielding + Environmental Flexible TPE Jacket
Plug: Double-Sided USB A Male to Double-Sided Micro B, Gold-plated Reversible Connector Heads
Output: 5V/9V/12V, up to 2.1A
Length: 1m/3.33ft
Color: Black, White
The cable uses a double-sided USB A male plug and a double-sided micro B reversible plug allowing you to plug it
in without needing to recognize the positive or negative, just like the apple lightning cable.Gold-plated reversible connector heads and 3.33ft/1m flexible TPE wire sheath with 24AWG power and 30AWG data tinned
copper wire cores, it can be bent over 3000 times and with no damage or change in performance.Supports 5V/9V/12V fast charging at up to 2.1A current, compatible with Qualcomm QC2.0, MTK Pump Express Plus and other fast
charging technology.Compatible with most of micro USB digital devices like smartphones, tablets, MP3 players, PDAs, digital cameras/camcorders,
hard drives, e-readers, power banks, portable game players etc.More details, click here.
Have fun,
Doris Lee -
