【HOT SALE】33% off ORVIBO WiWo-S20 Wi-Fi Smart Home Remote Control Timing Socket
  • #9694
    banggood
    Hi, dear DroidChina friends,
    Today I bring you a useful remote control timing socket, ORVIBO S20 smart plug apply with the newest SmartLink technology,
    wihich can connect with your router rapidly and also compatibility with all kind of socket. In that way, you can control the appliace with it in both the wifi and mobile internet.This smart socket can let you enjoy the great fun of smart life.:blush::blush::blush:
    Have you ever forget to turn off your lamp when you left home? Have you ever want to turn on the heating on your way back to home? Have you ever want to save energy at home?:angel:
    You never need to worry again. I highly recommended ORVIBO S20 to you, let’s see how it works.
    [size=large]ORVIBO WiWo-S20 Wi-Fi Smart Home Remote Control Timing Socket Power Plug[/size]
    [video=youtube]https://youtu.be/tfiOKlPuVV0[/video]
    [size=large]Main Features :[/size]
    ● Support WiFi network and phone data control
    ● Support Smart Configure Net Technology, Easy to Access Settings
    ● Home Appliances Status Timely to Feedback to APP
    ● Support Max 10 Timing Task
    ● APP Support Max 150 WiFi Sockets
    ● Support Max 20 Devices to Control WiFi Socket
    ● Easy installation, easy handling and can be activated immediately and stably
    [size=large]What can S20 smart socket help you :[/size]
    1 With it you’ll have much clever home appliances which know you better
    You can control your home appliances plugged into WiFi smart socket from anywhere as long as your smart phone connected with internet.
    You can control the on/off time of your home appliances according to your life style by setting the crontabs,
    2 With it, your home at your fingertips.
    It’s doesn’t matter even if you forget whether you close your home appliances or not because you can use WiWo app to see the on/off state of them.
    You can control all your home appliances plugged into WiFi smart socket through WiWo app.
    [size=large]Customer’s Operation Video Demonstration[/size]
    [video=youtube]https://youtu.be/X0zm79xPCzE[/video]
    [size=large]More warm note for your using :[/size]
    1. Pay attention to moisture and prevent them getting wet. Please Do not use in the barthroom!
    2. Rated power of S20 is 2,000W, it almost fit every house daily appliance, but still please be aware that some high power appliance might over it when it turn on.
    3. The product have 4 type plug optional, please ensure that you have selected the correct one according to your country before you order it
    More details, click here.
    Have fun,
    Doris Lee
