Samsung Galaxy Note 3 China No Signal
Home Forums Android Software Help Requests Samsung Galaxy Note 3 China No Signal
This topic contains 4 replies, has 5 voices, and was last updated by  ridarwp 4 years, 4 months ago.
Viewing 5 posts - 1 through 5 (of 5 total)
  • #5288
    juris
    I reset my Samsung Galaxy Note 3 (China) to it’s factory settings. What happened is that it has no network signal anymore. How do I restore the network signal? My unit reflects an IMEI number… still, no network signal.
    Please Help! Thanks
    #15835
    Change sim card, hope your sim slot damage or sim having a problem……
    selim can alkoƧ
    selim can alkoƧ
    #16239
    s7yler
    Did you try to set it to 2G only? and disable the auto mode / 3G?
    #17902
    bintsk
    Have you tried switching your phone off and restarting it? Sometimes, changing the SIM card also helps to fix this problem. Also, check if you have accidentally turned the Airplane Mode on.
    #18184
    ridarwp
    You have to try to switch off and restart it again? May be it will resolve your problem. Otherwise reset it then from BIOS boot.
