Phone not rebooting to recovery mode. Help Please. Thank you.
Home Forums Android Software Help Requests Phone not rebooting to recovery mode. Help Please. Thank you.
This topic contains 8 replies, has 9 voices, and was last updated by  martindrox 3 years, 10 months ago.
Viewing 9 posts - 1 through 9 (of 9 total)
  • #5359
    jayenn11
    Hey guys. I need help. I tried installing CWM recovery in my Mtk6589 Gt-19500 phone. It didn’t work after how many tries. Then suddenly, I can’t even reboot my phone in recovery mode. Pls help me. I’ve been doing so many things in my phone already. Im afraid it will get bricked or something. Thanks a lot guys.
    #15772
    zuklior
    have the same problem :(
    #15828
    Me too…….
    #15848
    If your battery charge ok, try volume+ and power button pressed together. If this does not work, try volume- and power button together.
    #16174
    Sam Bruces
    you can try to reset it to recovery or get flash rom stock from needrom.
    #16176
    jollie22
    i bought this phone before, too, and have the same problem, but i send it back the seller for repairing!
    #16265
    Giladi
    I had the same problem…
    #17697
    Rohan99
    I think you messed up the original recovery while trying to flash cwm. I flashed my phone with cwm recently and I had the same issue. I suggest you find a tutorial about installing cwm on mtk phones using a windows software. It works great so you can do that to get cwm.
    #17860
    martindrox
    I guess you ruined the original recovery, flashing your phone without knowing what to do is a big mistake. You should install cwm for the start by a computer cause you cant do it just by the phone.
