Wednesday, January 18, 2017
need help with buying external battery for galaxy s5
Home Forums Android Software General Discussions about Android need help with buying external battery for galaxy s5
This topic contains 2 replies, has 3 voices, and was last updated by  doray 2 years, 6 months ago.
  • #6400
    BULei
    please help! I want to buy this MPJ power bank and the sellers claims that it last for 2-3 days…please is this true? how effective is it….thanks in anticipation.
    #17496
    Rohan99
    How long the battery lasts all depends on the storage capacity in terms of the current. As to whether that battery lasts for 2-3 days, I think you should not take the seller’s word for it because after all he is trying to sell a product and will do everything to convince you to buy it. Check out some reviews on youtube or else where to see if you would be satisfied with it.
    #17669
    doray
    Heck Yeah..I’ve only used the battery. OK supplier.
