LED Laser Pointer Flashlight
Home Forums Android Software Apps, Games & Utilities LED Laser Pointer Flashlight
This topic contains 0 replies, has 1 voice, and was last updated by  killu 3 years, 9 months ago.
  • #12697
    killu
    The LED laser pointer is simulated in your display and your LED flashlight will turn on or flashes, if you like. You can select dozens colored laser pointers, laser rays, buttons, turn signal buttons, backgrounds and you can add or remove many additional LED settings. If you shake your device, then Laser and LED turns on and off, which you can disable. You can use the laser pointer as a widget by activating the start light function, then you just need to click on App Icon and instantly your LED light and laser pointer is very fast on. Matching on and off sounds and laser sound, you can select or deselect. Design your own colored laser pointer and adjust the flashlight settings according to your needs. Easy to use and a nice laser pointer flashlight for your smartphone and tablet. The colored laser pointer is simulated only the display, not in your LED camera light. Instead, your LED has very bright light and a flashing lights modus against darkness.
    Link to Download: https://play.google.com/store/apps/details?id=appinventor.ai_ali_kim_022016.LEDLaserpointerFlashlight
    [img]https://lh3.googleusercontent.com/4sjF6lkDxPJ9fllngAi7HW2bzTdVtTG9tFUVgVe0dd-ubm07iyDXFk_AryliyXPPz-TJ=h310-rw[/img][img]https://lh3.googleusercontent.com/9lg6jBiFqq2uQe3udbSwPmIWurB8fzsJcvEM185jBN7sx-2CvSSJck6q1UiXWoNxraw=h310-rw[/img]
