Monday, January 16, 2017
iwowfit V6 2-in-1 Smartwatch and Bluetooth earphone at $30 (coupon)
Home Forums Android Hardware News on Android Hardware iwowfit V6 2-in-1 Smartwatch and Bluetooth earphone at $30 (coupon)
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 6 months ago.
  • #11180
    With so many smart gadgets around you may get overwhelmed and ditch all of them at once. Imagine that you are a tech enthusiast and you have bought a  smartphone, a tablet, a smartwatch, a smartband and a Bluetooth headset. Not only do you have to charge all of them almost everyday, but you get frustrated by all those devices. Here is where the iwowfit V6 comes in.
    iwowfit v6
    Iwowfit V6 is a combination of a smartwatch, a smartband and a Bluetooth headset in one device. The 3-in-1 device acts as a smartband and a smartwatch while you wear it while it transforms into a Bluetooth earpice when you take it off its band. Using the device you can dial someone, make a call, control your music while you are out for jogging, rope skipping, sit-up as the device also records your mileage during jogging. It also incorporates a Pedometer and sleep monitor. Oh, it displays the time and acts as an alarm too.
    iwowfit v6
    When you take the main piece off the band, you get a fully functional Bluetooth earphone that can get you through 5-7 hours of continuous call or music listening. It supports Bluetooth 3.0 and 4.0 dual-mode connection and is compatible with Android 4.3 and up and iOS 7 and up devices.
    The iwowfit V6 is available for preorder at TomTop for $30.99 and you can get an extra 5% off by using the coupon VE5OFF. You can find it by following this link.
    iwowfit v6
