Bricked my phone, what to do?
Home Forums Android Software General Discussions about Android Bricked my phone, what to do?
This topic contains 1 reply, has 2 voices, and was last updated by  Benge 4 years, 10 months ago.
  • #8733
    edward918
    I own a BML One Mini which I have managed to brick.
    I’ve tried to enter recovery mode, but all that happens is this screen appears: [ATTACHMENT NOT FOUND]
    Then after about 5 minutes, the screen shows a progress bar for half a second, but then reboots, the normal android logo is shown at this point and the phone is stuck in a boot loop.
    I am unable to connect my phone via a USB cable to a computer too.
    How can I fix this?
    Thanks.
    #18665
    Benge
    did you follow this steps?
    1.Switch off your Android Phone.
    2.Press and hold together
    Volume Down + Power Key( If Keys Combination not work Use this General Templete )
    3.Release the buttons when you see an Android icon on your mobile screen Press the Power Button to see Recovery Menu.
    4.After Splash Screen a set of options will appear.
    5.In order to choose “wipe data/factory reset” Plz Follow instruction on your mobile Screen to navigate and to confirm
