Auto Root MTK6589 (One click root)
Home Forums Android Software How-to & Tutorials Auto Root MTK6589 (One click root)
This topic contains 450 replies, has 380 voices, and was last updated by  aladin 1 year, 3 months ago.
Viewing 15 posts - 1 through 15 (of 451 total)
  • #3755
    This tutorial is essentially the same as this one here:How To Root MTK6589 Tutorial
    It is also very similiar to rooting MTK6577 based Jiayu phones with a batch file mentioned here:Jiayu G2 & G3 simple root
    It is called auto root or one click root, because the rooting is done with a MSDOS batch file automatically. If you know how to click, you should be able to do it.
    It has been reported on various devices, including ZOPO ZP980/C2/ZP810, Feiteng H9500, Star X920 Butterfly, HDC Galaxy S4, Star S7189.
    Steps:
    1. If not already installed, install the USB drivers. Download the drivers from here, or use PDAnet drivers. Refer to this thread on how to install PDAnet drivers.
    2. Enable USB debugging on your phone from Settings > Developer options
    3. Download and extract Auto Root package in a folder on your PC
    4. Connect your phone
    5. Go to the folder you extracted Auto Root package files and run the “run.bat” file by double clicking on it
    6. Press any key to continue
      [img]http://droidchina.com/forum/attachment.php?aid=14[/img]
    7. Wait for process to finish and press any key again.
      [img]http://droidchina.com/forum/attachment.php?aid=15[/img]
    8. Your phone will reboot automatically. Congratulations! You now have a rooted phone.
    To help other rooters, please report back your phone make & model if this works or doesn’t work for you.
    Successful roots by members:
    Cubot A890 – danealegana
    THL W8 – nanimo, kelly2
    Star N9389 – paaaapryka
    THL W8+ – hendahewa
    Iocean X7 – 2alive
    #13112
    danealegana
    Great guide! I just had rooted my Cubot A890 with this guide.
    Just one reminder to those who already have working ADB drivers, you can skip installing pdanet drivers when you already have working ADB drivers.
    #13149
    ginco
    Sorry, but the .zip files seems be 0 byte
    #13150
    dcadmin
    It was a problem with the forum. Sorry about it. I’ve implemented a temporary workaround. You can download the file now. I will work on permanent solution.
    #13151
    dcadmin
    Everything is fixed now. Good luck with rooting!
    #13157
    nanimo
    thanks a lot, my Thl W8 is now rooted and work fine
    easy & good
    #13166
    ginco
    thanks dcadmin
    #13181
    kelly2
    THL W8 is rooted w/o any difficulties, perfect! Thank you.
    #13183
    Komponini123
    Shouldturn off my phone before plug it in ? Or I just have to leave it on and plug it like that ?
    #13184
    Turning the phone off is required during flashing with the flash tool. During rooting phone must me turned on.
    #13188
    paaaapryka
    Star N9389 succesfully rooted ;)
    #13189
    2alive
    It works for android 4.2.1 or just 4.1.2?
    Or does it work for both?
    #13190
    It should work for both if phone has MTK6589 chipset.
    #13192
    2alive
    Thanks, I want to root the Iocean X7, will try it.
    If it doesn´t work can it brick the phone?
    #13193
    There is always a risk involved during rooting. I don’t take any responsibility. However, in case of bricking, it may be possible to rescue the phone by re-installing official ROM using the SP flash tool.
