Tuesday, January 24, 2017
ZUK Z2 vs Xiaomi Mi5: Cheap Snapdragon 820 Phones Compared!
Home Forums Android Hardware News on Android Hardware ZUK Z2 vs Xiaomi Mi5: Cheap Snapdragon 820 Phones Compared!
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 7 months, 3 weeks ago.
  • #10832
    Xiaomi didn’t announce the successor to the popular Xiaomi Mi4 last year. This meant that the new flagship smartphone that the company announced in 2016 had to be perfect, satisfying the needs of the millions of Xiaomi fans worldwide. In a way, Mi5 did fulfill the need for a cheap Snapdragon 820 powered flagship, offering pretty good specs for a price tag of just over $305, at least in China. While many manufacturers found it hard to match Xiaomi in terms of its cheap pricing for Snapdragon 820, ZUK came forward and made sure its new ZUK Z2 phone came out as another cheap Snapdragon 820 option. In fact, if we stop and think, the ZUK Z2 is actually meant to be the Xiaomi Mi5 killer. The company already had two ZUK Z2 Pro variants, which were only a few bucks pricier than the Mi5. But it went ahead and released the ZUK Z2, in a separate conference. This does tell us something about the company’s intention with its new device.zuk z2 vs xiaomi mi5
    Since they are meant to be direct rivals, with similar specs and pricing, let’s take a look at the ZUK Z2 vs Xiaomi Mi5 comparison. We will see a lot of similarities in the design as well as the specs, but there will be a few differences as well. Let’s look at them in detail in the comparison down below.
    DESIGN:
    Design wise, they are very similar looking smartphones. Both the companies decided to opt for a glass back and a metal frame on their smartphones. While ZUK Z2 features a flatter back, the Mi5 comes with a slightly curved back panel, which should help in the grip. Both have their camera modules placed on the top left corner on the back, and the front features a compact 5-inch (5.15-inch on the Mi5) display with a front home button enabled fingerprint sensor.
    ZUK Z2 Measurements: 141.7 x 68.9 x 8.5 mm Weight: 149 grams
    Xiaomi Mi5 Measurements: 144.6 x 69.2 x 7.3 mm Weight: 129 grams
    As you can see, the measurements are almost the same, except for the thickness. Mi5 comes with a thin 7.3mm body, while the Z2 features an 8.5mm body. But there’s explanation to the increased thickness of the ZUK model, since it features a larger 3500mAh battery. On the other hand, the Mi5 comes with a 3000mAh battery. Since we are on the topic of battery, it’s important to mention that both feature Quick Charge 3.0 fast charging.
    ZUK Z2 vs Xiaomi Mi5 Specs:
    When it comes to the specs, both have very similar internals. Both the models are powered by Snapdragon 820 quad-core chipset. However, we are talking about the base variants, and the Xiaomi Mi5 standard version is underclocked to 1.8GHz. On the other hand, the ZUK Z2 is clocked at 2.15GHz, which can be overclocked further to 2.3GHz. So, on paper, the performance should be better than the Mi5. Then there’s the RAM on board. The base variant of the Mi5 comes with just 3GB of RAM, while the ZUK Z2 features 4GB RAM as standard. As for storage, you get 32GB on the Mi5 while the ZUK Z2 features 64GB. Both have non-expandable storages, so ZUK definitely gets a plus point in the memory department.
    Coming to the display, the Xiaomi Mi5 sports a 5.15-inch 1080 IPS LCD display while the ZUK Z2 has a 5-inch IPS LCD display. But the screen to body ratio on the Mi5 is higher, 73.1 percent as compared to 70.6 percent on the Z2. It is confirmed that the Mi5 has Corning Gorilla glass 4 protection, while we are not sure about the protection on the Z2.
    Coming to the camera department, the Xiaomi Mi5 seems to have an edge on paper. The phone features a 16MP rear f/2.0 shooter with 4-axis OIS, PDAF and dual LED flash. The camera has 1/2.8″ sensor size, and 1.12 µm pixel size. Coming to the ZUK Z2, it features a 13MP rear camera with f/2.2, EIS (electronic image stabilization), PDAF and CAF (Contrast Auto Focus) with LED flash. It has 1/2.6″ sensor size, and 1.34 µm pixel size. Both can capture 2K videos and slo-mo videos. Up front, the Mi5 comes with a 4MP f/2.0 camera while Z2 has an 8MP f/2.o sensor.
    Other features common on both devices include dual-band Wi-Fi ac, Bluetooth 4.0, fingerprint sensor embedded into the home button and dual SIM card slots. In the connectivity department, Mi5 has NFC and Infrared but ZUK Z2 doesn’t. The battery is larger on the ZUK Z2 as mentioned above (3500mAh) as compared to Mi5’s 3000mAh. Finally, for software, the Mi5 comes with MIUI 7 based on Android 6, while ZUK Z2 features ZUI 2.0 based on Android 6.0.1.
    Pricing & Availability:
    When it comes to the pricing of ZUK Z2 vs Xiaomi Mi5, after the recent promotion of the device in China, the prices are almost similar. Xiaomi had announced the Mi5 at around $308 in China at the time of launch, but now, the pricing seems to have gone down. International customers can now purchase the Xiaomi Mi5 base model for just $308 and with shipping included it still is well under $350. Coming to the ZUK Z2, it has an advantage of cheaper pricing as it is priced around $273. So, even after the premium charged by retailers, the pricing should be around $300, which at present is almost the same as the Mi5. Adding express shipping should still limit the price tag to well under $350.
    Availability is a different story though. Xiaomi seems to have stabilized the Mi5 stocks, and now, most retailers have the device in stock. As for the ZUK Z2, the phone is yet to go on sale, and the first sale is on June 7. Only after a few days will we know whether the Z2 is readily available for purchase in China as well as via third-party retailers.
    So, that was the ZUK Z2 vs Xiaomi Mi5 comparison. It would really be hard to choose between these two devices, but if you were going to buy one, which one would it be?
    We have already reviewed the Xiaomi Mi5. You can check it out from here.
