Monday, January 23, 2017
Xiaomi Max New Render Surfaces, Should Come With A Metal Body
Home Forums Android Hardware News on Android Hardware Xiaomi Max New Render Surfaces, Should Come With A Metal Body
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 8 months, 3 weeks ago.
  • #10601
    Next week, on May 10, Xiaomi will officially announce the Xiaomi Max phablet, the company’s first phone that will feature a 6-inch+ display. We have been hearing a lot about the device in the past few days, including the specs and the features of the device, and now, a new alleged render of the phone has surfaced online.
    mi xiaomi max render new
    The new Xiaomi Max phablet is said to come with a 6.4-inch display. This would make it a true phablet, which means it will be quite big. The new render does give us an idea about the form factor of the device, along with some other details. It looks like the Max will be designed a bit different than the Mi 5, abandoning the front facing fingerprint sensor embedded in the home button. Instead, there will be three capacitive keys. This could actually be a good sign,¬†since for such a large device, home button isn’t the ideal fingerprint location. Also, on top, you can see that the placement of the sensors are quite symmetrical, as revealed by earlier leaks.
    The frame of the phone is made out of metal and from the antenna lines seen near the bottom of the back cover, it looks like the device will feature a metal body. This could be a necessary move by the company since we saw earlier in a stress test video, Xiaomi didn’t last long under pressure. So, for a phablet of this size, metal would be ideal to keep it sturdy and strong.
    xiaomi max panel
    Earlier leaked xiaomi max panel
    As for the specs, the Xiaomi Max phablet is expected to come in two variants, one with 2GB RAM + 16GB ROM and another with 3GB RAM  + 32GB ROM. There should be the hexa-core Snapdragon 650 chipset inside. Also, the screen size is expected to be of 6.4-inches with 1080p resolution.
    The company will officially announce the device along with the new MIUI 8 OS on May 10. So, stay tuned for more details.
