Tuesday, January 24, 2017
XiaoMi Pad Specs Review
Home Forums Android Hardware Android Tablets Others XiaoMi Pad Specs Review
This topic contains 0 replies, has 1 voice, and was last updated by  james1991 2 years, 6 months ago.
  • #6365
    james1991
    The Xiao Mi Pad is an impressive device, with NVIDIA Tegra K1 quad core processing, lots of RAM and a sleek design, the XiaoMi Pad is sure to impress. Read on for a specs review.
    [ATTACHMENT NOT FOUND]
    General
    The XiaoMi Pad has some great specifications. These include:
    7.9inch FHD IPS Screen
    2048 x 1536 Resolution
    NVIDIA Tegra K1 Quad Core 2.2GHz Processor
    2GB RAM
    16GB Storage
    8MP Rear Cam
    5MP Front Cam
    Bluetooth 4.0
    Wireless
    The device is definitely packed full of high end specifications. This is great, especially considering the low price tag of $319.
    Display
    The display on the XiaoMi Pad is top notch. With a super high 2048 x 1536 resolution (above high definition), you will see every bit of detail in crisp clarity. Normally, such a resolution is reserved for a much larger screen. The 7.9 inch screen of this device is a great size for ultra portability. The high resolution means more can fit on the screen, and it looks great.
    Camera
    The good thing about the XiaoMi Pad is that it has two high resolution cameras, rather than just one on the rear. This makes for great photos, whether they are taken from the front or rear camera. The rear camera has an 8 megapixel resolution while the front camera has a 5 megapixel resolution. Both support digital zoom, and are able to record video.
    Connectivity
    The XiaoMi Pad features wireless, bluetooth, GPRS, EGDGE and HSPA. UNfortunately, the device is not 4G, nor does it have wireless N technology. Wireless B/G is decent and won’t slow you down too much. This only becomes a concern if you are into streaming HD content or games.
    Processor
    The XiaoMi Pad features an NVIDIA Tegra K1 Quad Core processor running at 2.2GHz. In combination with 2GB of RAM, this device is smooth and speedy. Multitasking is easy for the XiaoMi Pad and you won’t have to worry about closing apps in the background to keep things fast.
    Other Features
    The XiaoMi Pad also has 16GB of inbuilt storage that can be expanded via Micro SD. This is handy for those who like a bit of extra storage. The XiaoMi Pad also supports AVI, MP4, 3P, MoV, MKV and FLV files, so video playback is easy.
    Battery Life
    With a 6700mAh battery, you can expect around 150-200 hours of standby time. This is great for a tablet and really keeps things portable.
    Dimensions
    The XiaoMi Pad is actually a rather thin device. With dimensions of 202.1×125.4×8.5mm, it won’t feel too bulky. The screen size is perfect for web browsing and games, as well as video playback. Overall, a well sized device.
    Verdict and Price
    The price of this Android tablet is actually quite good, especially considering the super high resolution screen and variety of other features. The XiaoMi Pad is a great tablet for those who want portability, without sacrificing on screen size and quality. With data connectivity on the go, the XiaoMi Pad is even more portable.
    [FCT]11579-2[/FCT]
