Understanding MT6572, MT6582, MT6588, MT6592 basic parameters
Home Forums Android Hardware News on Android Hardware Understanding MT6572, MT6582, MT6588, MT6592 basic parameters
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 3 years, 2 months ago.
  • #4753
    MediaTek-Chips
    At present, many domestic smartphone manufacturer are equipped their products with MediaTek MT6572 and MT6582 chipset, and now those phone are already sold on the market. But I’m quite sure that not many people is understand about what the diferent between the MT6588 and MT6592 chipset. And now we want to show you about the short description about those chips.
    Here are the tabel of MT6572, MT6582, MT6588, MT6592 basic parameters, so that we have the impression, in order to tell you about.
    tabel chipset
    Process aspects: whether the low-end dual-core MT6572 or high-end eight-core MT6592, are used 28nm process. MT6572 and MT6582 which is the use of a common 28nm process, while the Advanced Edition Quad Core MT6588 and MT6592 is the use of 28nm HPM process, HPM is actually short for High Performance Mobile, meaning low-power mobile high-energy processes.
    Frequency and cache: frequency aspects MT6572, MT6582 uses a 1.3GHz, L2 cache which is mainly different. The Advanced version MT6588 is clocked using 1.7GH, L2 cache and MT6582 same. Eight core MT6592 is the use of an optional 1.7 ~ 2.0GHz frequency, while L2 cache upgrade to 1MB. According to current news, the first listing of eight core MT6592 will use the 1.7Ghz frequency, perhaps 2.0Ghz frequency will be the advanced version of the chip used in frequency, then the chip code should also be renamed.
    Memory : At present only Advanced version quad-core and eight-core MT6592 MT6588 increase LPDDR3 666MHz support. Compared to the now widespread use of LPDDR2, LPDDR3 bring a higher data transfer rate, bandwidth, energy efficiency, storage density, such as data rate of 1600Mbps, than their predecessors LPDDR2 1066Mbps add a whole half.
    Video coding: Only Premium quad and eight-core MT6592 MT6588 increase HEVC/V9 coding standards support. HEVC: High Efficiency Video Coding, is a new video compression standard. Support HEVC coding standards, for consumers, we can enjoy a higher quality of 4K video, 3D Blu-ray, high-definition television programs. In decoding mode, the MediaTek MT6592 decoding HEVC (H.265) FHD video consumes less power than the existing market quad-core solution for low 18%. In playback mode, MediaTek MT6592 can provide users with 20% frame rate improvement.
    GPU: the list of chips are used ARM Mali GPU processor family. Which ARM Mali 450-MP Die area of ​​8.6 mm2, based on quad-core design, built-in 256 KB L2 shared cache, running at 240MHz (40nm LP) or 480MHz (40nm GP), running at 480MHz speeds, the data throughput up to 104M triangles / s. In 4xFSAA (FSAA) mode, Mali 450-MP can provide the quality 2K and 4K display, support OpenGL v2.0 and OpenVG 1.1 effects.
    Maximum Supported resolutions: due to performance limitations, MT6572 supports only up QHD level, MT6582 supports HD is the highest level. Premium and eight nuclear MT6592 MT6588 is available up to 1080P resolution level.
    Network support: both support HSPA + Rel.8 21Mbps/5.76Mbps.
