Wednesday, January 18, 2017
Umi Fair Review
Home Forums Android Hardware News on Android Hardware Umi Fair Review
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 2 months ago.
  • #9460
    Thanks to Coolicool for sending Umi Fair for a review
    Umi Fair Review: VIDEO
    Umi Fair Review: UNBOXING
    IMG_4268
    What we have in the packaging are the UBS cable and a power plug.
    Umi Fair Review: DESIGN
    IMG_4297
    When it comes to the design, we are looking at a fairly compact phone due to its 5” display.
    Umi Fair is lightweight and sits comfortably in the hand due rounded corners and a soft somewhat baby skin finish on the back.
    IMG_4298
    On the front we have a 2MP shooter, earpiece and a sensor light. This time around, Umi chose to implement on-screen navigation buttons.
    IMG_4280
    The chassis is made of metal and on the right we have volume rocker along with the power key.
    IMG_4283 IMG_4285
    On the top there is a headset jack and on the bottom we have a charging port.
    IMG_4278
    As far as optics go, there is a 13MP shooter along with a dual LED flash.
    Right underneath the camera, there is a fingerprint scanner.
    IMG_4276
    On the bottom we have a speaker grill.
    IMG_4517
    The backplate can be removed and underneath it you can find a removable 2000mAh battery, 2 SIM card slots and a microSD card slot.
    Umi Fair Review: DISPLAY
    IMG_4291
    The Umi Fair comes with a 5” 720p panel, which is definitely not the sharpest we’ve seen but it’s pretty good for a budget phone. However, the sunlight visibility could be better.
    Umi Fair Review: UI
    The battery life is decent but nothing really impressive. I could get over 3 hours of screen on-time on a daily basis and doing just some basic tasks.
    Umi Fair Review: CONCLUSIONS
    IMG_4316
    I would call Umi Fair just another budget phone from China. Well, it has a decent design and good build quality.
    However, the main selling point, which is a fingerprint reader, does not work properly. It is very slow to setup and the real life usage is just a pain. It is not accurate and very slow, and it makes you want to turn this feature off.
    IMG_4313
    In general, I was happy with the UI performance but those Google Play store errors and a few app crashes were annoying.
    IMG_4299
    All in all, Umi Fair is not the worst phone we’ve seen in this price range but it is not the best either.
