Thursday, January 19, 2017
Two New ZUK Z1 Images Leak, Along With Some Specs
Home Forums Android Hardware News on Android Hardware Two New ZUK Z1 Images Leak, Along With Some Specs
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 5 months ago.
  • #8879
    ZUK Z1 is all set to debut on August 11, next month. And since the past couple of weeks, we have got a number of new renders as well as specs info about the upcoming device. In fact, the Z1 recently hit TENAA revealing the overall design of the phone.
    Now, two new pictures of the ZUK Z1 have surfaced online, giving us a closer look at the lower back region. These pictures are super clear and much better than the renders that were released by the CEO a few days back.
    ZUK-Z1 leak 01
    In the first image, you can clearly see the USB Type C 3.0 port at the bottom. Besides the port, there’s the speaker grill. And on the right, you can see the single microphone opening. Another important aspect revealed by this image is that beautiful metal frame that goes around the body. Finally, there’s the same ZUK branding on the lower back region as we saw in the previous images.
    ZUK-Z1 leak 02The second image shows us the SIM card tray that can be removed. It looks like the tray can hold two Micro SIMs. But doesn’t look like a MicroSD / SIM card combo tray.
    ZUK-Z1 03Finally, the third image reveals the 4G LTE connectivity details of the device. So, the phone will support 4G LTE connectivity specifically the following bands: 1, 3, 7, 38, 39, 40 and 41 and both TD-LTE and FDD-LTE networks.
    As for the specs, the company has confirmed 3GB of RAM, USB Type C 3.0 port, U-Touch Physical home button with fingerprint ID up front and 4000mAh + battery. What we are unsure about is the processor. ZUK could go with Snapdragon 808 like Motorola did with its recent Moto X Style. Also, we don’t know if there’s a MicroSD card slot on the device, but we sure hope so.
    Well, the device is turning out to be a true flagship smartphone in terms of specs as well as design. This makes us all the more excited to see the handset in real, which should be sometime after the launch on August 11.
