Sunday, January 22, 2017
Super Scales 2016
Home Forums Android Software Apps, Games & Utilities Super Scales 2016
This topic contains 0 replies, has 1 voice, and was last updated by  killu 6 months ago.
  • #11276
    killu
    Simply the best genuine digital scales app for Android and Windows Phone!
    Unlike some free and paid scales apps that only give you fake or made up reading Super Scales actually is the genuine thing and allows you to weigh small objects using just your smartphone! You dont really need any other equipment or device (except something to balance on). The only tool you will need for accurate weight readings.
    In this new version the weight measurements you can achieve can be as accurate as a real digital scales! This is the sequel to Super Scales Pro which has had over 1200 downloads and Super Scales Lite which has had over 60,000 downloads. It has a completely new and different scale algorithm giving a better acccuracy than before. It also features a new stabilization (optional via settings) method to give a defined stable weight reading. It also has a completely revamped GUI. Hence why its a new app as current users may be use to and like the old GUI.
    Please leave a comment and rate the app, or just rate the app. It will take you just 1 minute of your time or less but it helps us a great deal!
    Calibration:
    You can use any object of known weight for calibration like a 20 pence coin (6 Grams). Just place near bottom of the phone. Always place objects in same area for best accuracy.
    Super Scales 2016 Features:
    Brand new measurement algorithm
    Brand new reading stabilization method
    Brand new GUI for 2016
    Choose from 4 different units (MG, Grams, ounces and pounds (lb))
    Calibrate as many times as you want.
    Uses your phones built in tilt sensor
    Choose number of decimal places to display weight.
    Set your calibration weight.
    Switch off all ads in the settings!
    Links to full detailed video “How To” tutorial, shows you how to use the app.
    Things you can balance your phone on:
    Big closed bubble air bag.
    Large packet of crisps.
    A PC Mouse.
    A big Coke bottle on its side (but secured to stop it rolling).
    A football, basketball etc..
    Attach a large spring to the underside of your phone and place on flat surface.
    Even a banana
    Notes:
    The video tutorial is used under license from the uploader/publisher.
    We do not guarantee the accuracy of results, as it is dependent on your phone, whether your sensors are calibrated correctly and how you balance your phone. Also it is better to use a calibration weight close to the weight of the objects you will be weighing.
    Link to download: https://play.google.com/store/apps/details?id=com.sulaysa.superscales
    [IMG]https://lh3.googleusercontent.com/E23Z5XEQbLkqov40-rufYXjLzzcVBROkCIZnSLZoHBW6M1MYvrDTM3EPW1hq3Vngzxs=h900[/IMG] [IMG]https://lh3.googleusercontent.com/IbiHpsDrhor_QzRPP5_o2I6KDWHlgfovJK7R7fMe1s9PGlZlKdRO5TEl4FBOpRjuXa5W=h900[/IMG]
