Tuesday, January 24, 2017
Spreadtrum SC8810 MT6515 dead (urgent solution needed)
Home Forums Android Hardware Android Phones Others Spreadtrum SC8810 MT6515 dead (urgent solution needed)
This topic contains 12 replies, has 5 voices, and was last updated by  devilmaycry 2 years, 10 months ago.
Viewing 13 posts - 1 through 13 (of 13 total)
  • #4724
    sanaullah
    I rooted it which was absolutely fine but I tried to flash a custom rom onto it. I’m not going to lie I had no idea what this involved, what the risks were there , even I flashed it.
    Anyway during the installation of the new Rom seemed to be going fine with Research Download and after finish installing it was just died. Since then i cannot get it to turn on and it just doesn’t power up. It also won’t charge now.
    also when plugged into the PC it does not detected , so I’m hoping the fact it’s still recognized as something means there may be some hope left.
    plzzzz friends tell me what i do,
    I have no idea what I’m doing, I am just here with my lovely new phone not turning on.
    some persons have given idea of doing heating of the Processor IC / Processor Chip because of Boot ifailure , but how i do this process.
    help me friends now.
    Thanx in advance.:huh:
    #14731
    Sorry to hear that you’ve bricked your phone. You should still be able to flash new ROM using SP flash tool. But, make sure you get the correct ROM this time. You can check http://www.needrom.com or other internet sources, if manufacturer’s site does not help.
    Warning: heating the processor will not help in this case and may cause hardware damage!
    #14747
    sanaullah
    U r saying that “You should still be able to flash new ROM using SP flash tool. But, make sure you get the correct ROM this time”
    but i cannot turn on and it just doesn’t power up. It also won’t charge now, also when plugged into the PC it does not detected , so how
    plzzzz tell me what i do,
    Thanx
    #14748
    Does SP flash tool recognize and can flash it?
    #14750
    sanaullah
    Friend i have told that neither Computer detect it nor any other software including SP Flash tool recognize it.
    PLzzz tell me what i do?????
    #14762
    zhun1buy
    The evaluation of this kind of mobile phone is very good
    #14768
    sanaullah
    Evaluation means?????
    #14771
    1. Open device manager in control panel
    2. Remove your phone battery
    3. connect your phone to your PC with USB cable. Do you see any device show up in device manager? Do you see any device when you click scan for hardware changes button?
    4. Insert the battery and repeat step 3.
    5. Post the results.
    Please pay attention that device may show up in device manager only for 1-2 seconds and disappear. If it does, it should be flashable with SP flash tool. If not search internet for unbricking using pins. Like those below:
    http://forum.xda-developers.com/showthread.php?p=45930533
    http://www.androidnova.org/unbrick-your-hard-bricked-smartphone/
    Normally hard unbricking is not needed and either SP flash tool or recovery mode should work.
    #14778
    sanaullah
    No detection via device manager with battery n without battery.
    plzzzzz
    #15288
    now it is detected via USB so what now do???
    [hr]
    Now what is going on plzzzzzz
    #15289
    Find the correct rom for your phone and flash it using sp flash tool.
    #15291
    First how will i get correct ROM for my SPRD SC8810 and secondly phone detected via Research Download but Still not charging.Whats the issue???PLZZZZZ
    #16340
    devilmaycry
    Ohhhh I have the same problem but my phone is not completely dead the computer can detect it but I cant power it on :@ I have the same model that you have I flashed wrong .pac I am sure that your computer can detect your phone you have to be patient remove the battery many times and keep trying I all ready have rom backup
