Specs Review: JIAYU G2F Quad Core Android smartphone
Home Forums Android Hardware Android Phones Jiayu Specs Review: JIAYU G2F Quad Core Android smartphone
This topic contains 1 reply, has 2 voices, and was last updated by  antelifeUK 2 years, 5 months ago.
  • #6079
    There are many Big Android Phones going well in the market. But only few of them meet the standards, We means your Needs, some of them don’t fit in your budget and some of them don’t have features that you need. But JIAYU G2F MTK6582 Quad Core Android Phone meets all standards. You can get your favorite features at a very low price. It will not create too much load on your purse. Everyone can buy it from online stores and We can bet you will never complain about this Phone. If you want proof, then, let’s Review it closely.
    [ATTACHMENT NOT FOUND]
    JIAYU G2F Specifications Review
    This phone is released by JIAYU company to give competition to other Popular brands with extraordinary features at a low price.
    Display and Design
    Design wise it looks standardly fare with square corners. You will never feel that you have bought a low price phone. Now one can guess its price as it holds 4.3 inch Screen and 1280*720 pixel Screen resolution. You will also get Gorilla Glass 2 Protection which will protect the screen of this phone. It also has a multi – touch feature up to five fingers.
    Software specifications
    It comes with a MTK6582 Quad Core, 1.3 GHz Processor and with 1GB RAM and 4 GB ROM allows you to do whatever you want without facing any problems. This Processor will let you perform each task very quickly. So, A must need phone for you at low budget as you will not get same software specifications at this low price, Especially a phone running on Android 4.2.2 Jellybean.
    Battery
    As we explained it holds 4.3 Inch screen and with this normal screen size it have battery of 2200 mAh which is quite sensational. It will give you along backup, especially while listening songs and watching videos. If you are an internet freak than this battery can be very useful for you.
    Camera
    It provides main Camera of 8 MP with LED Flash and Auto Focus. The quality of Images and Videos captured by this camera is relatively Good. Additionally, it also has a 2MP Front Camera. In final words, you will enjoy capturing the important moments of your life in this Phone.
    Connectivity
    It provides Wi-Fi 802.11 b/g/n allowing you access Wlan hotspot and get high end Speed. You will also get GPRS, EDGE for internet connectivity. For data transfer you can use USB or Bluetooth 4.0 on this Mobile Phone. It also has the GPS facility for finding locations. So, in the end all features meet your needs as connectivity is very important in this modern Age.
    JIAYU G2F Full Specifications
    1. Screen:- 4.3 Inch, Multi-Touch
    2. Screen Resolution:- 1280*720 Pixel
    3. Processor:- 1.3 GHz, MT6582 Quad Core
    4. OS:- Android 4.2.2 Jellybean
    5. RAM:- 1GB
    6. Internal Storage:- 4GB
    7. External Storage:- Expandable up to 32 GB
    8. 3G:- Yes, WCDMA 2100MHz
    9. SIM:- Dual Sim, Dual standby
    10. Battery:- Li-on, 2200 mAh
    11. Weight:- 142g
    12. Main Camera:- 8MP with LED flash
    13. Front Camera:- 2MP
    14. Price:- $100-$125
    So, this ends JIAYU G2F MTK6582 Quad Core Android Phone Review. It is one of the best Phone at this price, but I wanna say it has some Cons also, as it don’t have OTA Upgrade Support, NFC Support and also No 1080p Display. It is still a best one because you can’t get everything with $100.
    [FCT]10523-2[/FCT]
    [video=youtube]http://www.youtube.com/watch?v=bQJlx5U3IjY[/video]
    [video=youtube]http://www.youtube.com/watch?v=M7kwlMEDhow[/video]
    [video=youtube]http://www.youtube.com/watch?v=Mle4VkOVEH4[/video]
    #17939
    antelifeUK
    thanks for the review
