Qualcomm Quick Charge? Sorry, Oppo is Aready a Step Ahead
Home Forums Android Hardware News on Android Hardware Qualcomm Quick Charge? Sorry, Oppo is Aready a Step Ahead
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 2 years, 7 months ago.
  • #6066
    3e53ca3d4e69bc938071715257cc62b9_w_680_h_425
    In recent years, the development of battery technology did not keep up with the pace of the development of improved mobile performance. Bio-batteries fuel these products andare still in the research state. Currently, we still technically rely on increased cell volume to increase the battery’s capacity.
    However, the battery capacity increases brought about the increase in charging time becoming longer. Standard charging current also increases the mainstream charging current from 600mA up to now 1A ~ 1.2A, which has now nearly doubled. Because of different battery capacity, the same charger, compared to iPhone and Android machines, tend to spend more time charging.
    Quicker charging rates will rise to two major problems: heat and reduction of the battery’s charging life. However, this makes the charging rate “less than 50% residual capacity palpitation”. At least one hour before the machine can be more than 50% of the electrical impulse. Manufacturers are beginning to think of new ways to solve this ongoing and serious problem.
    ca5fbbbddd0c0ff6c01f782c60c9d1b5_mw_680_wm_0_wmp_3
    Tip: The charging speed can be roughly calculated by: the Battery capacity / charging current. Analogy, a 2500mAh battery can be translated into 2.5Ah. If the charging current is 1A, then the charging time is 2.5Ah/1A = 2.5h, which is 2.5 hours. In fact, because the output of the charger is often less than the nominal value and the final process factors such as trickle charging, charging time takes longer than the theoretical time states.
    Qualcomm Quick Charge (referred to as QC)
    45e7f4b7b70aea2ca2053b78bf65fd2c_mw_680_wm_0_wmp_3 (1)
    In order to improve the charging speed, Qualcomm launched its QC1.0 technology to meet the Qualcomm chipsets and with a specific core premise of the largest mobile phone can accept 5V 2A input, so that the charging speed is greatly improved. Followed by the launch of QC2.0 technology, Xiaolong 800 helped with above CPU time and with the appropriate power management chip, phones can accept a maximum input of 12V 2A. By increasing the output power, it helps to increase the charge rate. However, the high-pass technique does not give details on how to control the temperature and the battery life.
    5fe8fdc79ce292c39c5f209d734b7206_mw_680_wm_0_wmp_3
    Qualcomm test machine battery is 3300mAh. Normal charge is used 5V 1A input. QC1.0 uses a 5V 2A input and QC 2.0 uses a 9V 2A input.
    So far, although there have been numerous phone hardware models supporting Qualcomm’s QC2.0 technology, including the HTC One (M8), 3 Unicom version of millet, etc., the charger side, even in the Almighty, cannot support QC2.0 charger. While Qualcomm QC has had excellent performance in the engineering prototype, on the practical application side, due to the lack of matching charger it is not practicality strong enough.
    OPPO flashing red technology
    There is another company in the fast-charging technology business that is out of the practical first step. The high-pass type, Oppo used its technology to increase the charging current which increased the charging power. Thus this increases the charge rate of the battery. Qualcomm’s technology is a combination of more Oppo self-developed technology.
    Judging from the appearance, Oppo for the improvements is to increase the charging port for charging and battery contacts. PR manager Oppo confirms some details of the technical aspects of their technology.
    Oppo flash red technology, through extra battery contacts for charging batteries in parallel, can be understood as a simple point. A few flashes of red while the battery is charging reduces the battery charge in a current single block, which now extends the battery’s life. Thanks to Oppo’s good relations with upstream manufacturers, the battery and the charger are individually customized, so that the battery can withstand relatively large current input.
    Battery Test from the forum displays, thanks to this new technology, finds that the battery’s heat levels, during the charging process, is in a controllable and appropriate range.
    b1f130b49d0fcfa2348098ee4467452f_mw_680_wm_0_wmp_3
    At room temperature at approximately 25 degrees in the environment, it will act normal. It will flash red during the maximum temperature unless it does not exceed 35 degrees, a temperature slightly higher than ordinary batteries. However, in the hot and humid southern summers, the temperature of the battery is still a cause for concern. If the thermal environment is not very good under the high temperature of the battery, the battery life will still be impacted.
    Furthermore, since the output power is relatively large, the charger is not as graceful looking as any other brand charger can hold. It is close to the size of a portable wireless router. In order to charge to necessary speed and volume it is understandable, after all, there is no charger technology that can reduce the volume.
    Summary
    In the category of quick charge, Qualcomm have already set the standard for mobile phone products that have hardware support, but did not push for QC2.0 support parts from manufacturers for its long term large-scale practical stance.
    Compared to Qualcomm, Oppo already have practical products and have successfully extended it to a certain extent on energy. We hope that this innovation can help improve battery life around the whole world.
