Oukitel U2 temporarily available for $ 89.99
Home Forums Android Hardware News on Android Hardware Oukitel U2 temporarily available for $ 89.99
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 5 months ago.
  • #8947
    This week Oukitel begins taking pre-orders for a budget smartphone U2.
    With the name of a famous rock band, comes the latest creation Oukitel young Chinese company that once they have manufacturing smartphones, carry a rate difficult to follow even for those who are dedicated to this.
    The first thing one sees when he first sees the Oukitel U2 is that it is a very nice smartphone.Not that this is a new design, (be difficult at this point), but of course, leaves a very good impression.
    The Oukitel U2 follows the design language of his older brothers, the U9 and U10 , and it makes use of a dual pane glass 2.5D and a rugged aluminum chassis CNC , which guarantees a good strength in its construction.U2 got a 5-inch qHD-screen, quad-core processor MT6735M, 1 GB of RAM and 8 GB of internal memory expandable, as well as support for two SIM-cards. “Out of the box” device works on the operating system Android 5.1 Lollipop.Oukitel U2 4G Smartphone Presale for  89.99.GeekBuying.comIn addition, the smartphone installed 8-megapixel main and a 5-megapixel front camera.
    But U2 Oukitel not stay in a nice design, but also integrates a modest hardware, but rather solvent for price range:
    • Name: Oukitel U2.
    • Display: 5-inch IPS 2.5D with resolution 960 × 540 qHD.
    • SoC: Mediatek MT6735m de 64 bits/4 núcleos Cortex-A53@ 1GHz
    • GPU: Mali-T720 MP4.
    • RAM:1 GB.
    • ROM: 8 GB expandable via microSD card up to 32 GB.
    • Rear Camera: 8 megapixel Sony sensor / lens of 5 elements
    • Front Camera:   5-megapixel.
    • Connectivity:  4G LTE with support Dual SIM, WiFi 802.11n, Bluetooth 4.0, GPS and FM Radio.
    • Networks:
      • 4G LTE: 1800, 2100, 2600, 800 MHz
      • 3G: 2100, 900, 2100, 900 MHz
      • 2G: 1800, 1900, 850, 900 MHz
    • Battery: 2050 mAh / Lithium-Ion.
    • Sistema operativo: Android 5.1 Lollipop.
    • Dimensiones: 70.5 mm x 143.0 mm x 8.5 mm
    • Peso: 148 gr.
    Buy from geekbuying.[source]
