Sunday, January 22, 2017
One Click Root
Home Forums Android Software Apps, Games & Utilities One Click Root
This topic contains 6 replies, has 7 voices, and was last updated by  Marryly 2 years, 7 months ago.
Viewing 7 posts - 1 through 7 (of 7 total)
  • #3370
    Memento_Mori
    “One Click Root is the world’s leading Android rooting software. With just a single click, you can root your Android smartphone or tablet and have access to hundreds of new and exciting features.”
    Click here to find out more.
    #12750
    man007
    Is there any application like this for Motorola Xoom 2? I really want to root it. If you have any information about it please tell me… ;)
    #12756
    Alex19
    I don`t recommend this kind of applications because you can get your phone bricked really easy. I prefer to do it the manual way, installing my roms with ODIN.
    #14686
    Rostafan
    One Click Root and Auto Root isn’t work in MTK6589 HDC MX9299A Android 4.2.1!!! Please HELP ROOT MY DEVICE!!!
    #14688
    ChiChai
    Try this? It looks easy enough. http://www.xoomforums.com/forum/motorola-xoom-2-development/15142-how-motorola-xoom-2-root-method-dan-rosenberg.html
    #15004
    abdelajel53
    sos : odin ne reconnait pas mon galaxy s3 mini tg 18190 !y’a il une solution?
    merci
    #17098
    Marryly
    How can I root Android device? Yes ,I use iStonsoft tool one click root Andriod devices.
