Wednesday, January 18, 2017
Note and Calendar
Home Forums Android Software Apps, Games & Utilities Note and Calendar
This topic contains 0 replies, has 1 voice, and was last updated by  killu 4 months, 3 weeks ago.
  • #11627
    killu
    Note and Calendar
    Record notes and calendar events with Note and Calendar. This note taking and calendar app is simple and easy to use. Simply take a note or use the calendar to schedule an event. You can set a reminder for a note by long pressing a note when saved. This notepad app allows you to sort a large amount of notes to quickly find what you recorded. The notes can be color coded to optimize organization. For example, an important schedule or event can be in red. You are sure to find many uses with Note and Calendar. Download this great easy to use and simple notepad app today!
    – Simple note taking with Note and Calendar
    – Complete calendar with event scheduling
    – Color coded notes
    – Sort notes by color, time or alphabetically
    – Lock a note to prevent modification
    – Deleted notes are sent to a trash bin just in case of a need for retrieval
    – Set a reminder to remind you about the note
    – Email the note to someone
    – Events are indicated on the calendar for easy reference
    Note and Calendar is sure to meet your daily needs as a useful note taking app. Try this simple and easy to use app.
    Try it today!
    Link to Download: https://play.google.com/store/apps/details?id=com.app.noteandcalendar&hl=en
    [IMG]https://lh3.googleusercontent.com/K-u_icqvQ8fUPSo-whz05W2tGaMTaJ5QD3M1egLum89QU61UlhH0r0bOIDN7PYFGcw=h900-rw[/IMG] [IMG]https://lh3.googleusercontent.com/t4JpCgFJE4CeejOFP0tR3XyAuuD427SZRLOcvNnkjy-tDxbMMgTXpugs1fn9MTr0shY=h900-rw[/IMG]
