Wednesday, January 18, 2017
Mediatek announces MT6735 and MT6753 SoCs with CDMA2000 support
Home Forums Android Hardware News on Android Hardware Mediatek announces MT6735 and MT6753 SoCs with CDMA2000 support
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 11 months ago.
  • #7841
    mediatek-cortex a7
    Mediatek has just unveiled two new processors in the market, namely the MT6735 and the MT6753. Both the SoCs are built on the 64-bit architecture. The MT6735 will come with a four core architecture while the Mt6753 will be much more powerful thanks to its octa-core architecture.
    The highlight of both these chips is probably its support for the new CDMA2000 technology. It supports both TD / FDD-LTE Cat.4 150Mbps, DC-HSPA +, TD-SCDMA, CDMA2000 1x / EVDO Rev.A, EDGE, which is true 4G full Netcom.
    The higher end MT6753 comes with eight Cortex A53 cores clocked at 1.5Ghz which makes it powerful yet battery efficient at the same time. The integrated Mali T720 GPU will make sure that the its graphic performance is impressive. On the other hand, the MT6735 processor will come with just four Cortex A53 cores.
    The MT6753 supports dual-band Wi -Fi 802.11n, and Bluetooth 4.0. Multimedia support include 1080p 30fps H.264 video recording and playback, 1080p 30fps H.265 video playback, 16-megapixel camera, PIP, Self-portrait, display output at 1080p 60fps, and MediaTek MiraVision support.
    Since, both the chips support 4G LTE and is targeted at the mid-range market, expect a lot of manufacturers to adopt these two processors in the upcoming smartphones.
    Both the processors are expected to be released by the end of Q2 2015.
    Meanwhile, here’s a comparison chart of the current Mediatek processors available in the market.
    mediatek processor comparison
