Wednesday, January 18, 2017
MT6592 three versions reviewed
Home Forums Android Hardware News on Android Hardware MT6592 three versions reviewed
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 2 years, 8 months ago.
  • #5977
    Before buying anything you need good comparison with something. In the world of technology, there is ‘war’ to make products better and leader in the race. So now the hottest eight core models will undoubtedly be seen as a powerful machine. These eight core models use MediaTek MT6592 CPU but frequency seems different. Here today we are going to look at the comparison and finally at the ending please do not forget to look at the differences between them.
    158932963
    0.3GHz How much bad MT6592 can be against the same door:
    There are two modes which are equipped with MediaTek eight core CPU, First one is MediaTek MT6592 and another is MT6592M. These are divided into MT6592 that is 1.7 GHz frequency and the other two version of 2.0 GHz frequency, and here in this article there are three brothers in three main characters.
    MediaTek eight cores can run simultaneously:
    In this current case, we could not found relevant information even in the website. There are limited documentation and information regarding this current MediaTek’s device. After reading this article readers will find satisfactory answer, as well as information.
    0.3GHz能差多少?MT6592同门三兄弟对阵
    0.3GHz energy difference? MT6592 0.3GHz MT6592 with the door against the three brothers
    0.3GHz能差多少?MT6592同门三兄弟对阵 0.3GHz能差多少?MT6592同门三兄弟对阵
    1.4GHz MT6592M CPU-Z parameters
    1.7GHz MT6592 CPU-Z parameters
    2.0GHz MT6592T CPU-Z parameters
    In fact these MediaTek MT6592 with MediaTek MT6592M in architecture and technology are identical, both processor are using the same 28-nanometer CPU technology, which is common in Smartphone and new modern processor but they also are using a 8-based Cortex-A7 core architecture. Both devices’ main differences are mainly related to the frequency and GPU frequency and it can create certain impact here.
    software running disparity, Measured performance:
    If you are interested in this DIY, computer users must be aware about the same architecture, cache, process, instruction sets and other parameters, Undoubtedly the best way to improve the performance is CPU clocking. We can see MT6592, MT6592M for a three versions of the frequency little or of no difference on performance, so then I have to prepare the scores to compare the differences between these devices. Many users are familiar with the software to run Sub ANTUTU and because of this article we are reviewing only MT6592, MT6592M clocked in the three versions of the CPU.
    1.4GHz MT6592M ANTUTU run points
    1.7GHz MT6592 ANTUTU run points
    2.0GHz MT6592T ANTUTU run points
    Floating point score of the integer three CPU is decreased in stepwise manner, which can be also the three sided shows and here frequency is only the parameter affecting their overall performance. I compared the all versions of the processor and GPU score in ANTUTU which has 3D and 2D drawing of two small items, 1.7GHz and 2.0GHz versions 1.4GHz’s MT6592M score is slightly lower, MT6592 score is basically the same,
    0.3GH MT6592Energy difference
    3D Mark score comparison Three versions MT6592
    After this I also used 3D Mark GPU for software testing on the Smartphone that they had been tested. From the test results we can see that both the Extreme mode or normal mode, 1.7Ghz and 2.0GHz scores are somehow same to the MT6592 of, 1.4GHz’s MT6592M score is slightly lower.
    0.3GHz MT6592 Difference
    Mali-450MP resolved
    MediaTek MT6592M and MT6592 models are equipped with GPU Mali-450MP, because its 1.7Ghz GPU frequency of MT6592 700MHz, As stated above we can read that the test version of the MT6592 2.0GHz GPU frequencies are 700MHz, and 1.4GHz. The MT6592M’s GPU frequency should be 600MHz. The things to be noted here is that, there is no view on the Android Platform currently. So the data drawn and conclusions in only inferred and no official data to support are found, that is why the article of mine exist.
    Practical experience of Video Test:
    At the final stage of test later, I have all three versions of these CPU’s also carried out some aspects of the actual experience, , not for users who bought the phone run points, so more concerned point here is experience differences in terms of users,
    Firstly, I tested the video on their terms to see if there are some difference between them or not. We evaluate then in 15 different formats on 1080 P video segment.
    1.4GHz MT6592M test results
    1.7GHz MT 6592 test results
    2.0GHz MT6592T test results
    Now here we can see three different versions of the supported formats MT6592 which slightly differ, except for the fact that these differences CPU are also because the Smartphone system itself and the some players decided that they are third-party installed player is normal play system, and in the fluency of the three versions of the processor does not exist qualitative difference, if observed by the naked eye we can’t find noted difference.
    Large-scale 3D game test GPU
    In addition to the video, the author also directed the three versions of the CPU to actual game, after all, in addition to scores of different CPU, GPU score seems to be different between them, while the gap on these scores could cause our experience will need to pass the test.
    I decided to test the game “Need for Speed ​​OL” as a test, because this is large 3D racing game for Smartphones. GPU ask for higher performance for feedback and more apparent. In addition to participating in the test model different CPU, RAM same as 2GB, we try our best on not to let other objective factors affect our test results.
    1.4GHz MT6592M running Need for Speed ​​OL Screenshot
    1.7GHz MT 6592 running Need for Speed ​​OL Screenshot
    2.0GHz MT6592T running Need for Speed ​​OL Screenshot
    Through the demo of Need for Speed ​​OL, we do not feel there is any difference in processor performance, and the screen and special effects have performed very well, they have not dropped frames, pixels etc. There seems some noted differences in GPU frequency but in actual use they don’t seems or feel a significant difference.
    Summary:
    And by the test running we came to find out noted differencess between MT6592M 1.7GHz/2.0GHz MT6592 and 1.4GHz, we found some of the noted difference in the score and performance. but it actually did not cause much gap in the actual experience so consumers won’t be disappointed. If consumer actually care about the performance or want to play big 3D and normal games then i recommend selecting of 1.7GHz/2.0GHz of MT6592M.
