Sunday, January 22, 2017
Leagoo M5: First Nano All-Metal Closed Loop Frame Smartphone
Home Forums Android Hardware News on Android Hardware Leagoo M5: First Nano All-Metal Closed Loop Frame Smartphone
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 6 months, 2 weeks ago.
  • #11136
    Leagoo has a new device called the Leagoo M5 and they are touting it as the first nano all-metal closed loop frame smartphone in the world. That is a pretty long description and I’m sure you do want to know what that means.
    Leagoo, in their own words says they have ”finally solved an engineering challenge after days of testing and focus to achieve a smooth and delicate all-metal frame body which has a tougher structure and delivers an amazing hand feeling”. To put it in simpler words, the phone features a tougher build quality and an amazing hand feel.
    Leagoo M5
    Leagoo says you should’t worry about the device suffering damages when it falls as the phone has been designed with a shock-proof panel to absorb falls.
    The Leagoo M5 has a 5.0” 2.5D HD bullet-proof glass display, 2GB RAM, 16GB ROM which can be expanded to 128GB via a SD card slot, 1.3GHz MTK6580A processor, an 8MP rear camera with flash, 5Mp for selfies, a 2300mAh battery said to last more than a day, and a fingerprint scanner that unlocks the phone in 0.19 seconds. The M5 also runs Leagoo’s Freeme OS 6.0 which is based on Android 6.0 Marshmallow, and has dual SIM slots with only 3G and 2G networks supported.
    Leagoo M5 1 Leagoo M5 2 Leagoo M5 4
    The Leagoo M5 is available in galaxy white, champagne gold, and titanium grey. There is no info about the price, but Leagoo says it is sure going to  affordable.
