Wednesday, January 18, 2017
JIAYU G4T Advanced, thin battery or thick battery version
Home Forums Android Hardware Android Phones JIAYU G4T Advanced, thin battery or thick battery version
This topic contains 2 replies, has 3 voices, and was last updated by  rellaz 3 years, 2 months ago.
  • #4723
    Summer
    JIAYU G4T Advanced has 2 different versions: thin battery version & thick battery version. I wonder to know what’s the difference between the two versions?
    #14749
    snowhill
    the thickness of their battery is different. Also, battery capacity is not the same, thick version is 3000mAh, thin battery version is 1850 mAh. hope this will help you!
    #14791
    rellaz
    Life dilemma – You always have to choose between battery size and capacity….
