In Stock! POMP CAIDAO C6S–best UMI X3 killer-first MHL smartphone
Home Forums Android Hardware Where to Buy 1949deal In Stock! POMP CAIDAO C6S–best UMI X3 killer-first MHL smartphone
This topic contains 0 replies, has 1 voice, and was last updated by  1949deal 2 years, 7 months ago.
  • #6081
    POMP has released its flagship smartphone [size=medium]POMP CAIDAO C6S [/size]now, this smartphone is really a great geek among android mobile device. Because it’s powered by MTK6592 Octa core 1.7GHz, with RAM 2G ROM 32GB internal memory, which is enough large to help you store the files you want like music, movies, games and so on. This smartphone has some unique features which can defeat other Chinese smartphones. That’s the [size=medium]MHL (Mobile High-Definition Link) function[/size], which is a new function of a smartphone, the role is like HDMI function, but is more powerful than HDMI, you can use your cellphone to connect other displays or other TV, if you connect by HDMI port, you can’t charge your phone at the same time, but if you connect by MHL, you can not only see the high definition 3D games or videos but also charge your phone in case of low battery. Therefore, it’s more convenient that you can enjoy the long-time playing games or watching videos. Facing this powerful smartphone, you need to have a good experience of it. It sells at $285.99 with three colors. One of them must be suitable your own taste.
    By the way, many users have mentioned that it can be best killer of UMI x3, my answer is yes. It really can unveil the new revolution of a high-end smartphone with MHL function.
    [size=medium]Check the main features of POMP CAIDAO C6S: [/size]
    – MTK6592 Octa Core 1.7GHz
    – 2GB Ram 32GB Rom
    – 5.5 Inch 1920*1080 FHD IPS OGS Touch Screen
    – 13.0 MP Rear Camera 8.0 MP Front Camera
    – Support 3G, GPS, WIFI, Bluetooth, Multilanguage, Play Store, NFC, OTG, MHL, etc.
    Do you wanna be the first one to experience MHL function of a smartphone? Do you think before about getting a real phone geek? Do you wait for the right time to change a new smartphone? If you are seeking the one you want, just stop here to have a good look. We [size=medium]1949deal [/size]will provide you with the best smartphone, great discounts, and fast shipping.
