Tuesday, January 24, 2017
Hyundai Ant 4 No GPS
Home Forums Android Software Help Requests Hyundai Ant 4 No GPS
This topic contains 0 replies, has 1 voice, and was last updated by  Picollo30 1 year, 5 months ago.
  • #8882
    Picollo30
    Hyundai Ant 4 with 4-inch capacitive screen, dual core processor and 512MB RAM, providing stable performance for compact terminal ideal for an intermediate user.
    CaracterĂ­sticsa:
    Android 4.4.
    MTK6572, Dual Core, 1.0 GHz
    DUAL SIM
    IPS 4 “, WVGA 800 * 480
    Specifications:
    Display: 4 “, 10 cm
    Resolution: WVGA 800×480 IPS
    Processor: MTK 6572, Dual Core, 1.0 GHz
    RAM: 512 MB
    Flash Memory: 4 GB Flash
    System
    OS: Android 4.4.
    Wireless
    GPS
    Bluetooth
    2G: GSM 850/900/1800/1900
    3G: WCDMA 850/2100
    Front Camera: 0.3 Megapixel
    Rear Camera: 2.0 Megapixel
    Battery: 1300mAH, 3.7V
    Accelerometer
    Connections
    Double SIM slot
    Micro USB (OTG)
    3.5mm headphone jack
    Micro SD slot (up to 32GB)
    ok guys i need your help. i rooted my phone with kingroot and after that the gps stopped working, it was working before maybe its a coincidence?
    i have android kitkat 4.4.2 installed and now when i go to settings / location, i have no location services available. no A-GPS, no GPS sattelites option nothing. plus in location mode there’s only one option available battery saving (use wifi to determine location) the other two device only and high accuracy dont show up.
    what’s going on?
    Also i installed Mobile Uncle and in MTk Engineering Mode the location tab is empty, it shouldnt be empty right?
    Installed GPS Status & Toolbox and keeps saying looking for gps location. it cant get gps signal.
    Finally i did factory reset but it didnt work. i dont know what to do anymore.
