How to regain access to an Android device after forgetting pattern unlock / PIN – See
Home Forums Android Software How-to & Tutorials How to regain access to an Android device after forgetting pattern unlock / PIN – See
This topic contains 0 replies, has 1 voice, and was last updated by  juvette 2 years, 6 months ago.
  • #6611
    juvette
    If you can’t gain access to your Android device due to forgetting the Voice unlock, PIN, pattern lock, slide lock or password protection then here are some methods you could employ. some of these methods will also teach you how to hack and bypass Android Password/Pattern/Face/PI
    Unlock using Google account
    If the Android device is associated with a Google account then simply supply your credentials to regain access. If mobile network data isn’t enabled then you can use WIFI. WIFI can be enabled in ABD ( *Note: USB Debugging needs to be enabled).
    In ADB, type:
    adb devices then press Enter
    adb shell svc wifi enable then press Enter
    Wipe pattern in adb
    * In adb, type the following
    adb devices press enter
    adb shell press enter
    cd data/system press enter
    su press enter
    rm *.key press enter
    * Now, remove the battery then boot the phone.
    * If presented with a lock screen, just enter any pattern and you’ll be granted access
    Source: How to regain access to an Android device after forgetting pattern unlock / PIN
