How to make screenshots
Home Forums Android Software How-to & Tutorials How to make screenshots
This topic contains 9 replies, has 8 voices, and was last updated by  MaryChris 3 years, 1 month ago.
Viewing 10 posts - 1 through 10 (of 10 total)
  • #3373
    Hold down volume down and power buttons for about one second and screenshot will be saved under screenshots folder in pictures directory.
    #12730
    lindbergh
    For my smartphone, I hold the menu button plus the power button to capture the screen. This comes in handy when I need to get a snapshot of what I’m doing on the phone which could later be used for articles or for presentations. If you’re not so keen on doing this, you could download apps to do this for you.
    #12737
    man007
    Very cool trick. But it didn’t worked for me… I have the xperia neo v. Which version of android I have to have on my phone?
    #12742
    Works on Jiayu G2 with Android 4.0.4. But it should work on others too.
    #12757
    Alex19
    It doesn`t work for my Samsung Galaxy S. After I searched the internet, it seems that the righ combination of buttons is this : Hold down the home button and press the back button.
    #12833
    it depends on the phone. my phone is the starmobile astra. i hold the power button and a pop up appears with options to either turn off my phone or take a screenshot.
    #12882
    lindbergh
    Some new Smartphones like the Samsung Galaxy Note 2 makes it so easy to make screenshots. All you need to do is to swipe your hand across the screen and a screenshot would automatically be taken! You could also capture a specific object on screen by drawing around the object using the stylus.
    #12890
    NextLT
    This a pretty cool trick!
    It worked for me.
    #12937
    Artixion
    Cool trick man thanks for sharing
    #15209
    MaryChris
    That’s very convenient. But I used Android Transfer to take screenshot on Android device since it can save the screenshot on my computer.
    What’s more, Android Transfer allows me to manage my photos at the same time.
    Read the guide here may provide you enough information about this tool: http://www.transphone.net/android-transfer/take-screenshot-on-android.html
