Helio P10 MT6755 Spotted On Geekbench, Faster Than Snapdragon 615!
Home Forums Android Hardware News on Android Hardware Helio P10 MT6755 Spotted On Geekbench, Faster Than Snapdragon 615!
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 4 months ago.
  • #9236
    At the start of the year, Mediatek rebranded its high-end lineup as the Helio series. While the Helio X (X stands for Extreme Performance) series was meant to cater to the needs of a flagship with top-notch performance, the Helio P series (P stands for Premium) was targeted at the mid-range flagship smartphones.
    Mediatek unveiled the Helio P10 MT6755 octa-core chip on June 1st, however, we have not yet seen a smartphone running this SoC. As a result, the performance of the handset is still not known.Helio-p10-benchmarks
    Yesterday, Mediatek MT6755 or the Helio P10 was spotted on the Geekbench results, revealing the performance of its eight-cores for the first time. According to the results, the P10 managed to score 882 in the single core test, and 3371 in the multi-core test. In comparison, the Snapdragon 615 scores only about 700 points in the single core and 2700 points in the multi-core tests on an average. As a result, it looks like the Helio P10 will be much faster than the Snapdragon 615 chipset. However, we have to take into consideration that the 615 is a year old chip. When it comes to performance, the new Snapdragon 620 will definitely give the Helio P10 a run for its money (acc. to rumors).
    Other specs of the Helio P10 include 2GHz, True Octa-core 64-bit Cortex-A53 CPU, 700MHz, Dual-core 64-bit Mali-T860 GPU, WorldMode LTE Cat-6, MediaTek’s CorePilot for optimized system load management, and MediaTek’s Non-contact Heart Rate Monitoring which uses the smartphone’s video camera to take heart rate readings.
    Well, things are definitely going to get interesting in the mid-range and high-end smartphone segment in the coming months, with a number of powerful chips including Helio X20, P10, Snapdragon 820 and 620 expected to release before the end of the year.
