Wednesday, January 25, 2017
HTC One Max 809d starting their debut in China
Home Forums Android Hardware News on Android Hardware HTC One Max 809d starting their debut in China
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 3 years, 3 months ago.
  • #4594
    HTC One X 809-02
    According to Telecommunication Equipment Certification Center MIIT in China , HTC One Max that has code 809d model or another varian of HTC One Max unlocked version is ready to starting their debut in Chinese market.
    This phone is packs with 5.9 -inch full HD 1080p , while in the processor is reliability of the quad core 1.5GHz processor which is believed to be the Snapdragon S4 Pro and not using the Snapdragon Snapdragon 600 or 800.
    Coupled with 8 megapixel rear camera and 2.1 megapixel front facing camera, the phablet has 164.5 × 82.5 × 10.29mm body design and has 217g of weight. It also comes with 2GB of RAM and 64GB of internal memory which supports MicroSD card expansion slot.
    Thanks to support for GSM and CDMA2000 cellular network, this phone is also running based on Android 4.3 Jelly Bean operating system is likely to be devoted exclusively to the operator is under the auspices of the China Telecom.
    HTC 809d-01
