Get the Original Huawei AM08 Mini Bluetooth Speaker for only USD29.99 at Geekbuying.c
Home Forums Android Hardware News on Android Hardware Get the Original Huawei AM08 Mini Bluetooth Speaker for only USD29.99 at Geekbuying.c
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 7 months ago.
  • #8599
    Huawei has always been known for creating high-quality products at very competitive prices from smartphones, to wireless modems, to speaker, and now you can get the Huawei AM08 Mini Bluetooth Speaker is now available at Geekbuying.com for only USD29.99.
    geekbuying-huawei-am08-bluetooth-speaker-01The Huawei AM08 features a Little Swab design that’s both portable and lightweight. The speaker is made from 2.5mm thick durable ABD engineering material and outputs 5 channels of impressive surround sound with its top-mounted speaker.
    On the top of the device is a 5-way control key that controls volume, next and previous songs, and Bluetooth pairing. The 5-way control key also houses the device’s microphone for answering incoming calls. It uses a CSR Bluetooth 4.0 chip to connect up to two devices simultaneously up to 10 meters away.
    The speaker is equipped with a 700mAh battery which gives the device over 24 hours of standby time and up to 4 hours of continuous usage. Charging the device only takes less than 3 hours via its micro USB port. Lastly, the Huawei AM08 comes with a user manual and charging cable.
    Buy Now
    geekbuying-huawei-am08-bluetooth-speaker-02 geekbuying-huawei-am08-bluetooth-speaker-03
