Friday, January 20, 2017
Flagship Battle: Zeaplus M7 vs Elephone P7000
Home Forums Android Hardware News on Android Hardware Flagship Battle: Zeaplus M7 vs Elephone P7000
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 7 months ago.
  • #8564
    With the number of flagship devices available in the market today it’s a bit difficult to choose which one to purchase. So we’ve put the latest flagships from Zeaplus and Elephone – the M7 and the P7000 – against each other to see which one is better and narrow down your possible choices.
    zeaplus-m7-vs-elephone-p7000-01
    Display
    Both the Zeaplus M7 and the Elephone P7000 feature a 5.5-inch IPS screen with a display resolution of 1920 x 1080 pixels. Both screens also feature Corning Gorilla Glass 3 protection. This means both of them will display almost the same image and video quality.
    Cameras
    Both devices feature 13-megapixel and 5-megapixel rear and front-facing cameras, respectively, but the Elephone P7000 features a newer Sony IMX214 and an aperture of f/2.0 compared to the Sony IMX135 and f/2.2 aperture of the Zeaplus M7. In this category, the Elephone P7000 is the clear winner.
    Processor & RAM
    The Zeaplus M7 and the Elephone P7000 are both powered by a MediaTek MTK6752 64-bit octa-core processor clocked at 1.7GHz. They also both come with 3GB of LP-DDR3 RAM. This means both devices should perform similarly.
    Storage
    Storage is also another area where the Zeaplus M7 and Elephone P7000 match as both devices come with 16GB of internal storage and support expandability via microSD up to 64GB.
    Battery
    While the Elephone P7000 features a 3,450mAh battery, the Zeaplus M7 comes with a larger 3,800mAh battery giving it an advantage over the P7000 in battery life.
    Price
    While the Zeaplus M7 can be purchased for $199.00 or cheaper ($149), the Elephone P7000 ends up more expensive at around $229.99.
    Conclusion
    Since Zeaplus M7 and the Elephone P7000 feature a lot of the same specifications and each is better than the other in certain ways when it comes to their differences, it makes it difficult to see which device is better. While the Zeaplus M7 is equipped with a larger battery and is cheaper, the Elephone P7000 features a better camera but is more expensive. It will fall down to whether you want a cheaper phone with more battery life or better photos but for more money and a shorter battery life. Which one would you pick?
