Tuesday, January 24, 2017
[FREE] Ringtone Maker
Home Forums Android Software Apps, Games & Utilities [FREE] Ringtone Maker
This topic contains 0 replies, has 1 voice, and was last updated by  killu 1 year, 11 months ago.
  • #7828
    killu
    A cool new app Ringtone Maker
    ★★★ Introducing Ringtone Maker ★★★
    [IMG]https://lh6.ggpht.com/uVA6rYRHtcAyRYUF7YHIaF0RArmKaLtwDEOTBLroo4KxQytiyG2J3syIdaZ2uhFu7jE=h900[/IMG] [IMG]https://lh6.ggpht.com/BmPe3CLV37VvE0fa6T8iNt-5qpZoIB0LTet2XZYUZiMZLY3mQBSZfVyUE0grVrQD7k30=h900[/IMG]
    Description :
    Ringtone Maker
    Have you ever thought of becoming a Ringtone Maker from songs?
    Our app Ringtone Maker Pro is one of the best free apps in the google play store that lets you create and edit your alarm sounds, ringtones and other audio notifications. To put it simply, our ringtone maker app allows users to create their own ringtones out of MP3 songs and other audio files. Pretty neat right? Not only this but our app also has some great features that you will learn when you continue to read more.
    Our ringtone maker supports several audio file formats like:
    – MP3
    – WAV
    – AAC
    – MP4
    – 3GPP
    Do you love a certain song? Everybody loves to have a good ringtone. Some people prefer certain parts of a song. Default ringtones that you can find on the internet may not give you the personalized ringtone taste you are looking for. There are certain limitations in customization when it comes to using default ringtones. Sometimes pre made ringtones may be to short or too long, or certain songs are hard to find if they are not popular enough. If you are listening to songs that are not considered as mainstream, you will find it very hard to look for a ringtone from your favorite songs.
    The best method to hearing favorite parts from your favorite songs is to use a ringtone maker to customize your own ringtone. If you have a copy of your favorite song, you can use our ringtone maker app to cut a portion from that song to be used as a ringtone. Our Ringtone Maker Pro lets you create ringtones from your own personal music library or record new ring tones even on the fly! Try our app now to make the best personalized ringtone!
    Our ringtone maker from songs have several features:
    – Cut, Paste and Copy features.
    – Enable Fade in and Fade out for MP3 files.
    – You can adjust volume for MP3 files.
    – You can view scrollable waveform representation of audio files.
    – Trim starting and end points for an audio clip using an easy touch interface.
    – Ringtone Maker allows you to save clipped audio files and rename it as you please.
    – You can preview ringtone demos before saving.
    – Allows you to record a new audio clip for editing.
    – Ringtone Maker app allows you to assign a ringtone to a contact.
    – You can also re-assign or delete ringtones as you see fit.
    Ringtone save path:
    Ringtone: sdcard/ringtones
    Notification: sdcard/notifications
    Alarm: sdcard/alarms
    Music: sdcard/music
    So do you want to be a ringtone maker from songs today? Check out our ringtone maker app now to be able to self-customize your own ringtones as you see fit. Now you can use the favorite parts from your favorite songs to be used as ringtones for your smart phone.
    Link to google play: https://play.google.com/store/apps/details?id=com.nodem.ringtonemaker
    Requires Android: 3.0 and up
    I recommend you to download this new and awesome app.
    Enjoy!!
