Tuesday, January 24, 2017
Elephone Announces Custmized YunOS for S2 and S2 Plus Will Be Available Very Soon
Home Forums Android Hardware News on Android Hardware Elephone Announces Custmized YunOS for S2 and S2 Plus Will Be Available Very Soon
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 1 year, 5 months ago.
  • #8994
    Elephone Announces Custmized YunOS for S2 and S2 Plus will be available for the fans very soon. Elephone tweeted on twitter and it comes handy to Gizmochina.
    Elephone S2/S2 Plus is the Double-side glass device released by the company. It is Ultra Slim 6.8mm in size. Both are amazing screen smartphone which are fully glass coated. The 5.0 inch screen in S2 is most suitable for single hand grip while 5.5 inch screen in S2 Plus would gain a broader field of vision. It wholly depends on your taste.
    Outlook of S2 can hardly be felt, and inside of it is powerful beyond your imagination. MT6735 quad-Core 64-bit processors and 2GB & 16GB SD combination provide S2 amazing driving force.
    S2 adopts the latest OS -android 5.1. The OS Promotes the android’s overall stability and reduces the power consumption. The rear camera with 13mp of S2 enables you capture more details. F/2.2 aperture largely improves the ability of filming under low light and gets depth of field for macroshoting.
    Well you can check the device description and full details on Elephone website.
    If you like it and love to have an awesome device like this, you can purchase it from Gearbest.
